Assembly Occurrence Suppression
Message 1 of 9
I've seen a lot of posts about Feature Suppression.
Is it possible to suppress certain "part occurrences" within an assembly? I'd prefer to do it in VB if someone can point me in the right direction.
Replies (8)
Message 2 of 9
Hello jimpe,
No, you cannot 'Suppress' an Occurrence, but depending on what you are trying
to implement, setting the visibility of a given Occurrence might suit your
needs:
"oAssemblyDocument.ComponentDefinition.Occurrences(1).Visible = False"
Cheers,
Adam
> assembly?
> direction.
Message 3 of 9
Thanks Adam. Would anyone from Autodesk like to confirm that you cannot 'Supress' an assembly occurrence?
I don't think disabling the visibility would have the desired affect in the assemblies .idw or the parts list, but I will try it.
Thanks again.
Jim
Message 4 of 9
Jim,
Adam is in fact from Autodesk. Nevertheless, I can confirm his statement
that suppression of occurrences is not currently supported. Why do you need
to suppress them?
Sanjay-
wrote in message news:5034673@discussion.autodesk.com...
Thanks again.
Jim
Message 5 of 9
Making an Assembly Occurence both "not Visible" and marked as "Reference"
will "suppress" it.
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP2
"Sanjay Ramaswamy (Autodesk)" wrote in
message news:5034715@discussion.autodesk.com...
Jim,
to suppress them?
Sanjay-
Thanks again.
Jim
Message 6 of 9
Sanjay,
I have an assembly made up of custom iparts. I'm using VB to 'changerowofipart' for different versions of the assembly. There is one part however, that is either a 45degree housing or a 90degree housing. The two versions are too dissimilar to incorporate into one ipart. My thought was to put both versions in my base assembly and depending on which assembly version I need, suppress one of the housings and use the other.
Teun,
Thanks. Turning off visibility and setting the BOM Structure to Reference removes it from the parts list in the .idw and makes it's line type phantom (which I can turn off).
Adam passed along the code for visibility, do you know what the VB code would be to set the BOM Structure to Reference?
Thanks again.
Jim
Message 7 of 9
Simple:
Sub ChangeToReference()
Dim oAssemblyDocument As AssemblyDocument
Set oAssemblyDocument = ThisApplication.ActiveDocument
oAssemblyDocument.ComponentDefinition.Occurrences(1).BOMStructure =
kReferenceBOMStructure
End Sub
T. Ham
Mechanical Engineer
CDS Engineering BV
2 GB SDRAM
3Com Gigabit NIC
wrote in message news:5037602@discussion.autodesk.com...
Sanjay,
Teun,
Thanks again.
Jim
Message 8 of 9
Thanks Teun, that worked fine.
Message 9 of 9
Jim,
Do you still have this code? If you do, please pass it on. Thanks
