Assembly Loop to pass sub assembly name to parts
NachoShaw
Advisor Advisor
Message 1 of 9
NachoShaw
Hi
is there any code about that would help me do the following from the top level assembly?
loop assembly
identify each sub assembly & get the part number
identify each part within that sub assembly and add the part number to a custom property
cant seem to figure it out...
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (8)
Message 2 of 9
There is a way but it's a bit complicated (rule based adjustment of the partname and replacing the old part with the new part in the main assembly). I want to create a guide on how to do it along with other usefull information on programming inside assembly's with iLogic and include custom snippets to it. Take for example making assembly's endless with the use of multiple standard and variable parts.
The other side is that it will take me about 2 weeks fulltime to complete and i want the information that more people are interested in this to make it worth my time.
Message 3 of 9
NachoShaw
Hi
I should mention that im not looking to rename any parts or assemblies, i just want to get the parent assembly part number and place the value in a custom field field in the child parts / assemblies
Nacho
Message 4 of 9
machiel.veldkamp
Hey!
You can loop through the whole assembly like this:
https://forums.autodesk.com/t5/inventor-customization/recursive-bom-need-some-help/m-p/8823958#M9791...
(last post in the link)
in SetRowProps() you can add another argument where you just pass the name of the parents name in RecurseBOMRow()
So for example:
Sub SetRowProps(oCompDef As ComponentDefinition, QTY As Integer, oTotalDict As Dictionary(Of String, Integer), ParentQTY As Integer, ParentName As String)
You'd have to enter that information when you call it of course:
Call SetRowProps(oCompDef, oBOMRow.TotalQuantity, oTotalDict, newParentQTY, <a Dim that holds the name of the parent>)
Note: for what you're doing it's probable (definitely is) way overkill to do it like this but you can do it like this.
But here's a question:
What are you going to do when one part occurs in multiple assemblies?
also... How are you going to use it? (why do you need the info there in the first place?)
___________________________
Message 5 of 9
NachoShaw
Hi
Its mainly for documentation. i need to add the name of the parent assembly into the sub parts / assemblies so that we can get the parent assembly listed in the titleblock. Also, if the parent assembly name already exists, than i will add to it so that it becomes a list. we have a large field that shows the result. It would be very similar to 'Where Used' in Vault.
so, it would be best to be a combination of occurrence & reference (because an occurrence loop takes longer)
From Top Level
get assembly part number
    loop assembly
    add part number in iproperty for each component part / assembly
        if component = assembly, get part number of that assembly, loop that assembly and add part number
the reason i say reference over occurrence is because the reference will return 1 result per component whereas the occurrence will return all instances which would take longer
so as a set of results;
top level = 1234-0670
-part 1 = 1234-8566 (Parent = 1234-0670)
-Part 2 = 1234-5833 (Parent = 1234-0670)
-Assy2 = 1234-2855 (Parent = 1234-0670)
--Part 3 = 1234-6355 (Parent = 1234-2855)
--Part 4 = 1234-9144 (Parent = 1234-2855)
--Assy 3 = 1234-6994 (Parent = 1234-2855)
---Part 5 = 1234-7455 (Parent = 1234-6994)
---Part 6 = 1234-5345 (Parent = 1234-6994)
--Part 7 = 1234-0451 (Parent = 1234-2855)
-Part 8 = 1234-4222 (Parent = 1234-0670)
unless we can access the WhereUsed property in a part?
Nacho
Message 6 of 9
Try this:
Sub main()
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Call createcostumprop(oDoc)
Dim occ As ComponentOccurrence
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
	For Each occ In oDoc.ComponentDefinition.Occurrences
		If occ.Name = "" Then GoTo 1 :
		Call createcostumprop(occ.definition.document)
			Call processubassembly(occ)
		1 :
	Next
End Sub
 Sub processubassembly(occ As ComponentOccurrence)
oDoc = occ.Definition.Document
Dim Subocc As ComponentOccurrence
	For Each Subocc In oDoc.ComponentDefinition.Occurrences
		If Subocc.Name = "" Then GoTo 1 :
		Call createcostumprop(Subocc.definition.document)
			Call processubassembly(subocc)
		1 :
	Next
 End Sub
Sub createcostumprop(Odoc As Document)
customPropertySet = Odoc.PropertySets.Item("Inventor User Defined Properties")
Try
	customPropertySet.Item("Costum Property").Value=Odoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Catch
    customPropertySet.Add("","Costum Property")
End Try
End Sub
Message 7 of 9
machiel.veldkamp
Do you output that to a textfile?
Also.... can you post it when you are done? I like the idea!
Message 8 of 9
NachoShaw
Hi
no im actually checking each component during the loop for a custom iproperty. if it doesnt exist, it will get created and then the part number of the parent assembly will be placed into the custom field. Then when the part / assembly is placed onto the sheet, the parent assembly / assemblies are listed so that fabrication can refer to the documentation. The part number is the same as the drawing number.
Nacho
Message 9 of 9
Then change the code to get the assembly part number in a ipropertie to:
mainOdoc= Thisapplication.ActiveDocument
Try
customPropertySet.Item("Costum Property").Value=mainOdoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Catch
  customPropertySet.Item("Costum Property").Value=mainOdoc.PropertySets.Item("Design Tracking properties").Item("Part Number").Value
End Try
End Sub
