Assembly Axis intersect
cozziU28ZM
cozziU28ZM
With Ilogic it's not possible but with API I think so but I don't have the slightest idea how to create one
rule that shows with "MessageBox.Show()" every x,y,z point of the "Plane Ref" of the "Roof" part in which every axis Apx1 Apx2 or more
Axis with name "Apx" added in assembly  (search with ... For Each ... In ...) that intersect.
WCrihfield
Hi @cozziU28ZM.  What do you intend to do with that information once you get it?  Do you need the intersection point coordinates to be in the context (3D coordinate space of the ComponentDefinition) of the main assembly, or in the context of the Roof part?
Wesley Crihfield
(Not an Autodesk Employee)
cozziU28ZM
In the context of the Roof part!
Because in the assembly when I add part with Apx... inside in correspondence with the coordinates on the Roof part I create holes.
cozziU28ZM
