Assembly a spring
Assembly a spring
Assembly a spring
I am trying to assembly a spring, but I couldn't select any circle to insert the spring 1 end to a hook, another end to a boss.
It's difficult to explain in words, so I will provide screenshots.
I can provide the assembly file if needed.
Is there any way to solve the problem? I heard about creating work axis but I am not sure how to do it.
Binga
If you create a work axis, you can use it to assembly. Have you tried it?
If you can share the assembly we can see better the problem.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Hi thanks for replying. I tried creating 2 axis, but I still can't select them, not sure why. I have attached the assembly file, do let me know possible solution to solve this issue! Thanks a lot for your help! 🙂
Not sure how to edit the question hence I replied to it with attachement of assembly file. Do help me if possible! Thanks in advance..
Binga
You will need to zip all files of the assembly and share.
The iam file just contains the relations between the files.
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Oh noted. Please find attached, hope is workable? I am using v2014
Hi, can anyone teach me how to solve this? I can't get my axis to assembly.... Thanks..
