Arrange sketch symbols
snichols
Message 1 of 14
snichols
I am working on some drawing automation. I have an ilogic rule that inserts a sketch symbol based on centermarks from the model. This all works fine. However I need a way to arrange these after they are inserted. I have the code below that returns all of the Y values for the sketch symbols. My thought is I need to make a list in ilogic for all of these and compare the values. How would I do this is the question? The model can any number of components located at various elevations as shown in attachment.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
oDrawDoc.Update
oSheets = oDrawDoc.Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
For Each oSheet In oSheets
     For Each oSymbol In oSheet.SketchedSymbols
          If oSymbol.Definition.Name = "label" Then
                Dim oSymbPoint As Point2d
                oSymbPoint = oSymbol.Position
'              MsgBox(oSymbPoint.x & " - " & oSymbPoint.y)
                'next steps are:
                'Create a list of all the oSymbPoint.y values and compare them to see if any overlap and how much (oSymbPoint.y +/- 1/16" to check overlap)
                'If any overlap move them and retest to make sure the move didn't cause any others to overlap
                'Keep checking and moving until none overlap
     Next
Next
'Code below for moving the sketch symbol'                ' Set a reference to the TransientGeometry object.'                Dim oTG As TransientGeometry'                oTG = ThisApplication.TransientGeometry'                '                'Move the sketch symbol if it is too close to another one.'                Dim oNewPoint As Point2d'                oNewPoint = oTG.CreatePoint2d(oSymbPoint.x, oSymbPoint.y + 1) The "+1" would be the amount of overlap'                oSymbol.Position = oNewPoint
Replies (13)
Message 2 of 14
JelteDeJong
you can try some thing like this.
' Create the list
Dim theList As List(Of Double) = New List(Of Double)()
			' Adding the y values to the list
            theList.Add(oSymbol.Position.y)
    Next
Next
' Here is the list actual sorted
theList = theList.OrderBy(Function(x) x).ToList()
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 14
snichols
Ok, so I can get the list and sort the list. Now what I need to do is get the specific sketch symbol associated with one of the values in the list. If I wanted the sketch symbol associated with item 3 in the list how would I get that? Is it even possible?
The sketched symbols all have the same name "label", so returning the name wouldn't help. It would need to be the occurrence of that symbol.
my code is below:
oDrawDoc.Update
Dim oSheet As Sheet
Dim MyArrayList As New ArrayList
'Dim RefKey As Long
                MyArrayList.add(oSymbPoint.y)
     Next
Next
myArrayList.Sort
Elevations = myArrayList.Count
Iterations = (Elevations-1)
test = InputListBox("Select one.", myArrayList, myArrayList.item(0), "iLogic", "List")
'RefKey = myArrayList.item(0).ReferenceKey 'This does not work'test2 = MessageBox.Show(RefKey, "Symbol Reference")
Message 4 of 14
JhoelForshav
Hi @snichols
I rewrote your rule a little to use a dictionary(of double, SketchedSymbol) instead. Using that one your selection knows which symbol it's referring to. Try this ilogic rule. Notice how the SketchedSymbol related to the selected Y-position from the inputbox gets selected on the drawing 🙂
oDrawDoc.Update
Dim oSheet As Sheet
Dim oDict As New Dictionary(Of Double, SketchedSymbol)
				oDict.Add(oSymbPoint.Y, oSymbol)
     Next
Next
Dim sorted = From pair In oDict
             Order By pair.Key
oDict = sorted.ToDictionary(Function(p) p.Key, Function(p) p.Value)
Dim oSelectedSymbol = oDict.Item(InputListBox("Select one.", oDict.Keys, oDict.Keys(0), "iLogic", "List"))
Dim oSelSet As SelectSet = oDrawDoc.SelectSet
oSelSet.Clear
oSelSet.Select(oSelectedSymbol)
Message 5 of 14
snichols
Thank you for the reply, however I am getting the below error with the code. I'm on Inventor 2017 if that makes a difference. I probably should have stated that from the start. 😞
Message 6 of 14
snichols
Below is my latest code, it doesn't work. It fails at the "Call". I was trying to get the reference key of the symbol.
oDrawDoc.Update
Dim oSheet As Sheet
 Dim nKeyCont As Long
'Calling this method is a must
nKeyCont = oDrawDoc.ReferenceKeyManager.CreateKeyContext
'Get the reference Key from occurrence
Dim oOccRef() As Byte
     Next
Next
myArrayList.Sort
Dim oString as Object
For i = 0 To Iterations
Try
For Each oString in myArrayList
        If myArrayList.item(i + 1) - myArrayList.item(i) < 0.125 Then
            'Set a reference to the TransientGeometry object.
            oNewPoint = oTG.CreatePoint2d(oSymbPoint.x, myArrayList.item(i) + (0.125 * 2.54))
            'need to specify which symbol to move here, below does not work
            Call myArrayList.item(i + 1).SketchedSymbol.Definition.GetReferenceKey(oOccRef, nKeyCont)
            i = i + 1
Next
Catch
End Try
Next
RuleParametersOutput()
InventorVb.DocumentUpdate()
 What i am trying to accomplish is to move one of the sketch symbols (with code) that are at the same elevation. There are currently 6 sketch symbols named "label", but you can only see 5 in the drawing (see attachment) because the ones at 10'-0" are on top of one another. I need some way to identify the symbol that needs moved but I don't know how to get the symbol from the list item. Anybody have any ideas?
Message 7 of 14
JhoelForshav
I've only been able to try it on 2020 and 2018 and unfortunately i connot reproduce the error...
It might help to add a reference to system.linq
AddReference "System.Linq"
Imports System.Linq
oDrawDoc.Update
Dim oSheet As Sheet
     Next
Next
             Order By pair.Key
oSelSet.Clear
If that doesn't work, maybe @AlexFielder can help? I see this thread is solved:
https://forums.autodesk.com/t5/inventor-customization/using-linq-with-inventor-ilogic/td-p/5136712
But I'm not really sure exactly what was done to make it work.
Message 8 of 14
snichols
I was able to get the rule to run somewhat by adding the import, however when there are 2 or more sketch symbols with the same elevation it throws an error stating an item with the same key has already been added.
Message 9 of 14
JhoelForshav
@snichols
I still think the best way to be able to select a symbol from a list is to use a dictionary. I'd suggest using index to prevent getting list items with the same name, like inventor does in the browser tree (Ex: Part1:1, Part1:2, Part 1:3, Part2:1...)
Try this iLogic rule to see what i mean 🙂
Imports System.Linq
oDrawDoc.Update
Dim oSheet As Sheet
Dim oDict As New Dictionary(Of String, SketchedSymbol)
			Dim i As Integer = 1
			Dim yString As String = oSymbPoint.Y.ToString & ":" & i
			While oDict.ContainsKey(yString)
				yString = oSymbPoint.Y.ToString & ":" & i
				i += 1
			End While
			oDict.Add(yString, oSymbol)
	Next
Next
Order By CDbl(pair.Key.Split(":")(0)), CDbl(pair.Key.Split(":")(1)) 'Order by y-pos first, index second
oSelSet.Clear
Message 10 of 14
snichols
This is great! However I need to automatically select the ones that need moved based on the values in the list. I've never done anything with a dictionary before so I have no clue how to go about it. My thought was something like below but it didn't work. If you could point me in the right direction I would be most appreciative!
For Each oDict.Item in oDict.Keys
i = 0
    If oDict.Keys(i + 1).Value < oDict.Keys(i).Value + 0.125 Then
    Dim oSelectedSymbol = oDict.Keys(i + 1)
    oSelSet.Clear
    oNewPoint = oTG.CreatePoint2d(5, oDict.Keys(i).Value + (0.125 * 2.54))
    oSelectedSymbol.Position = oNewPoint
Next
Message 11 of 14
JhoelForshav
@snichols
In our dictionary the Key is a string based on the Y-position and an index. The value is the aqual SketchedSymbol.
Now that i know what you want, it wasn't really necessary to use a dictionary. A list of all the symbols would be enough. I thought you wanted to be able to select a symbol from an inputlistbox...
But now that we've already written the code with a dictionary, lets keep it that way.
I believe this is what you want 🙂
Imports System.Linq
oDrawDoc.Update
Dim oSheet As Sheet
				i += 1
			End While
	Next
Next
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
For i = 0 To oDict.Count - 2
	If oDict.Values(i + 1).Position.Y < oDict.Values(i).Position.Y + 0.125
		'Dim oNewPoint As Point2d = oTG.CreatePoint2d(5, oDict.Values(i).Position.Y + (0.125 * 2.54))
		'If you want them all to have x = 5 then uncomment line above and comment out line below.
		Dim oNewPoint As Point2d = oTG.CreatePoint2d(oDict.Values(i + 1).Position.X, oDict.Values(i).Position.Y + (0.125 * 2.54))
		oDict.Values(i + 1).Position = oNewPoint
Next
Message 12 of 14
JhoelForshav
Sorry!
I accidentaly deleted the line that sets oDict to the sorted dictionary!
It should be like this:
Imports System.Linq
oDrawDoc.Update
Dim oSheet As Sheet
				i += 1
			End While
	Next
Next
Next
Message 13 of 14
snichols
You are THE MAN! That is just perfect! TYVM for the help!
Message 14 of 14
JhoelForshav
