Arc As Bend
Arc As Bend
Arc As Bend
Wish to create a sweep:
Profile: blue rectanlgle in the yellow workplane.
Guide Path: line from pt1 to pt5, arc from pt5 to pt7, line from pt7 to pt8.
I could create lines fine. Then for Arc3D, there were two options:
3Point: pt5-pt6-pt7. DID NOT WORK as the arc was not like a fillet.
ArcAsBlend: gave lines pt1-pt6 and pt6-pt8 as input. It created the arc but left some portion. Using this path I am not able to create the sweep.
Code below:
    Dim v3 As Vector = v1.CrossProduct(v2)
    Dim uv3 As UnitVector = v3.AsUnitVector
    uv3.AsVector.ScaleBy(offsetdistance)
    Dim point5 As Point = point1.Copy()
    point5.TranslateBy(uv3.AsVector) ' TRANSLATE by Offset distance
    Dim point6 As Point = point5.Copy()
    point6.TranslateBy(uv3.AsVector) ' TRANSLATE one more time, just for some offset
    Dim point7 As Point = point6.Copy()
    uv1.AsVector.ScaleBy(m_bendradius) ' TRANSLATE same in the Perpendicular direction
    point7.TranslateBy(uv1.AsVector)
    Dim point8 As Point = point7.Copy()
    uv1.AsVector.ScaleBy(heightdistance) ' Go by Height distance
    point8.TranslateBy(uv1.AsVector)
    Dim wpt1 As WorkPoint = m_compDef.WorkPoints.AddFixed(point1)
    Dim wpt5 As WorkPoint = m_compDef.WorkPoints.AddFixed(point5)
    Dim wpt6 As WorkPoint = m_compDef.WorkPoints.AddFixed(point6)
    Dim wpt7 As WorkPoint = m_compDef.WorkPoints.AddFixed(point7)
    Dim wpt8 As WorkPoint = m_compDef.WorkPoints.AddFixed(point8)
    Dim oSketch3d As Sketch3D = m_compDef.Sketches3D.Add
    Dim skln1 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(wpt1, wpt6)
    Dim skln2 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(wpt6, wpt8)
    Dim skbend As SketchArc3D = oSketch3d.SketchArcs3D.AddAsBend(skln1, skln2, m_bendradius)
    Dim oPath As Inventor.Path = m_compDef.Features.CreatePath(skln1)
Picture attached
Vladimir.Ananyev
AddByBend method should give you the desired result if the he both lines end points are merged.
I’ve slightly changed your code to get the correct profile:
Dim oLine1 As SketchLine3D
Set oLine1 = oSketch3d.SketchLines3D.AddByTwoPoints(oWorkPoint1, oWorkPoint2, False)
Dim oLine2 As SketchLine3D
Set oLine2 = oSketch3d.SketchLines3D.AddByTwoPoints(oLine1.EndSketchPoint, oWorkPoint3, False)
Dim oArc As SketchArc3D
Set oArc = oArcs3D.AddAsBend(oLine1, oLine2, "2 mm")
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
