ApprenticeServerDrawingDocument - PartsList
tore.marskar
Message 1 of 1
tore.marskar
Hi
(Inventor 2025, .Net 8.0)
sh.Name returns the expected string, so the objects is at least partially OK.
I get an exception 'Not implemented (0x80004001 (E_NOTIMPL))' when I try to get the parts lists of the sheet. A simple null check throw the same exception.
Get the same exception if i try to get the sheets Title Block. Seems strange that two such important features should not be implemented.
Inventor.ApprenticeServerComponent apprentice = new Inventor.ApprenticeServerComponent();
Inventor.ApprenticeServerDocument apprenticeDoc =
    apprentice.Open(fileName);
Inventor.ApprenticeServerDrawingDocument drw = apprenticeDoc as Inventor.ApprenticeServerDrawingDocument;
foreach(Inventor.Sheet sh in drw.Sheets)
    string plName = sh.Name;
    Inventor.PartsLists pls = sh.PartsLists;
Replies (0)
