Apprentice vs Full Inv API
Raider_71
Raider_71
Hi I wonder if anyone could shed some light on a small issue I am experiencing.
Basically what I need to do is extract the current Workspace path and current Project Name during my external application load event. So I am also trying to make the application not reliant on Inventor running in the background so I opted for using apprentice. The problem is that apprentice does not quite work that well when trying to get this information.
If I use the full Inventor API then all works fine.
'Get current project file info
            Dim oInvApp As Inventor.Application = Nothing
        Try
            oInvApp = Marshal.GetActiveObject("Inventor.Application")
            strWorkspacePath = oInvApp.FileLocations.Workspace
            strWorkspaceName = oInvApp.DesignProjectManager.ActiveDesignProject.Name
        Catch
        End Try
When using apprentice like this then it does not actually retrieves the last active project info.
        Dim oInvApp As New Inventor.ApprenticeServerComponent
        Try
        Catch
        End Try
So here is the procedure I am following:
Start Inventor
Current project = "Project A" with workspace "c:\temp\A"
I then activate "Project B" with workspace "c:\temp\B"
If I run my app with full Inventor API I get the correct info.
If I run my app with using apprentice I get project A's info
Why would this be happening? Its almost like the app has not updated the registry with the new active project information??
Thanks.
Jon.Dean
Great question Pieter,
I'm sure the current project is saved to the registry because I tested using the Task Scheduler and that found the current project file.
I have asked one of the developers, hopefully they will come back to me.
In the meantime I will do some testing.
Jon.
Jon Dean
Jon.Dean
Hi Raider_007,
Have you checked the 2015 API Object Model; see below:
Here you can see where the project path is defined.
Jon.
Jon Dean
