Apprentice Server COM Exception with Inventor 2015
RonaldDold1034
RonaldDold1034
i have some sample code from the Mod The Machine Blog, which runs on Inventor2012 without problems,  but with Inventor 2015 it throws an exception.
I have no idea whats going wrong.
(Code from: http://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-2.html)
Private Sub CreateImage( _
              Apprentice As Inventor.ApprenticeServerComponent, _
              PartOrAssembly As Inventor.ApprenticeServerDocument, _
              Filename As String)
   ' Create a new camera.
   Dim cam As Inventor.Camera
   cam = Apprentice.TransientObjects.CreateCamera
   ' Associate the document with the camera.
   cam.SceneObject = PartOrAssembly.ComponentDefinition
This last line throws a  "System.Runtime.InteropServices.COMException"
I know that this have worked with Inventor 2012 as i have build a small "Snapshot" App with this code.
Any Ideas?
adam.nagy
Autodesk Support
Autodesk Support
Hi Ronald,
It does seem to be an issue 😞 and so I have logged it in our system, #110672
I cannot think of a workaround other than using Inventor (e.g. in the background)
Cheers,
Adam Nagy
Autodesk Platform Services
sverduyn
It seems this is still a problem with Inventor 2017, Catastrophic Failure when you try do the above!!
adam.nagy
Autodesk Support
Autodesk Support
Unfortunately, it seems this has not been sorted yet 😞
I'll try to raise the priority on this.
Cheers,
Adam Nagy
sverduyn
Thanks, fortunately I can run inventor silently and then use the camera object, not ideal as I want to run it on the vault server!!
