Apprentice Poofs
Apprentice Poofs
Apprentice Poofs
Is anyone else having Apprentice shut down the program occassionally?   I am trying to process a lot of files, many of which have missing references, duplicate file names in the path etc.
My standalone exe program will run fine for a while but then it will just shut down, (form closes and program not shown in the task manager) and the last command was always apprentice trying to open a file.   If I restart my program and have it open the file that it crashed on, it opens it fine, but then a while later it crashes on another one. I go through this all day long.
I have tried everything I know to try and catch an error, but it doesn't seem to throw one.
I know one answer is to clean up the files so there arent the missing refs etc, but it isn't my data and I have little to no control over it.
Anyone else having these kind of issues with Apprentice.  I am seeing it on two different machines, with two different programs and two different datasets.
Ralf_Krieg
Hello
Seen this on running out of memory. And second, if you watch Inventor Taskplaner running on migrating a lot of files, you'll see something around 50 files, the running Inventor instance is killed and started again. There must be a reason for.
Don't know why, but maybe you should do the same.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Hi Krieg,
Thanks for the reply.  I really don't think I am running out of memory.   I have thought about killing the instance of Apprentice and re initializing it, but sometimes I crash after a couple of files, and other times I crash after 400 files.
It seems to have something to do with files that can't find their references.
xiaodong_liang
Autodesk Support
Autodesk Support
I am not sharing a comment, rather I'd be interested if the crash occurs with any document whose reference files are missed? or crash randomly?
