Apprentice API and Un-Enabled Parts
SteveLainson6531
SteveLainson6531
I'm looping through occurrences and wishing to exclude those that are not enabled from a List but although the parts/assemblies are not enabled in my .IAM I'm looking at the API doesn't seem to recognise this.
oOcc.Excluded does trigger a response but I cant figure out if this means suppressed, visible or enabled or some hierarchical  combination of these?
The code below does not trigger any response but oOcc.Excluded does - Looking at my model I think may flags visible OR not Enabled.
Can anyone explain for me please?
Dim oOcc As ComponentOccurrence
For Each oOcc In Occurrences
            If oOcc.Enabled = False Then
                Debug.Print(oOcc._DisplayName & " is not ENABLED.")
            End if
Next
A.Acheson
Excluded according to the API help refers to iAssemblies so I would guess this is not what your after.
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-28F8CC6E-F7EF-4DCC-AB95-06522C2DEF2F
Enabled and visibility:
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-19E2C95A-1AF1-466D-B97C-811388A31F15
Most occurrence in there normal state is set to be enabled as true. Maybe you want to check if visible or suppressed?
Regards
Alan
SteveLainson6531
Thanks for your help, after some digging I found the problem - its the LoD. By default Apprentice seems load the Master LoD and hence why it was not reporting any suppressed/non enabled etc. parts so I had to OpenWithOptions. This link solved my problem https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/open-document-in-last-saved-level-of-de...  - the useful bit of code is below.
Dim strFullFileName As String
    strFullFileName = "C:\temp\Assembly1.iam"
    ' Set a reference to the FileManager object.
    Dim oFileManager As FileManager
    Set oFileManager = oApprentice.FileManager
    ' Get the name of the last active Level of Detail (LOD) Representation.
    Dim strLastActiveLOD As String
    strLastActiveLOD = oFileManager.GetLastActiveLevelOfDetailRepresentation(strFullFileName)
    ' Use the full file name and LOD name to get the full document name.
    Dim strFullDocumentName As String
    strFullDocumentName = oFileManager.GetFullDocumentName(strFullFileName, strLastActiveLOD)
     ' Create a new NameValueMap object
    Dim oDocOpenOptions As NameValueMap
    Set oDocOpenOptions = oApprentice.TransientObjects.CreateNameValueMap
    ' Open the document.
    Dim oDoc As ApprenticeServerDocument
    Set oDoc = oApprentice.OpenWithOptions(strFullDocumentName, oDocOpenOptions)
