Apprentice and File Paths
My first foray into Apprentice server so bear with me.
Using the Assembly tree example as a staring point I have added a click even
to the tree view. I return the display name of the file (which is the same
as the filename in my case).
I now want to find the full path of the selected file based upon the current
project file.
I don't see a way to find the full path of the file unless I load the
document into apprentice (which I will do AFTER I find the full path).
Chicken and the egg...
Any suggestions?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
You need to look at the referencedfiles... This will loop through the
entire assembly.
Dim odoc As ApprenticeServerDocument
Set odoc = oApprenticeApp.Open("C:\Test.iam")
If odoc.DocumentType = kAssemblyDocumentObject Then
Call GetSub(odoc)
Sub GetSub(subdoc As ApprenticeServerDocument)
For i = 1 To subdoc.ReferencedFiles.Count
stName= subdoc.ReferencedFiles.Item(i).FullFileName
If subdoc.ReferencedFiles.Item(i).DocumentType =
Call GetSub(subdoc.ReferencedFiles.Item(i))
Next i
End Sub
"Sean Dotson" wrote in message
news:510D188ED957876F41431F9CFAC9541B@in.WebX.maYIadrTaRb...
even
same
current
> project file.
> Any suggestions?
> Sean Dotson, PE
Without trying a few things, I think what you will probably need to do is to set a
reference to the assembly upper assembly and then find the occurrence name in the assembly
and set a reference to it.
something like this
Set odoc = oApprenticeApp.Open(txtFilename.Text)
Dim sFilename As String
sFilename = treList.SelectedItem
Then find the instance that matches sFilename..... I imagine you will have to compare
against the parent tree nodes also?? to be sure to get into the right sub.
Does that make sense?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> project file.
> Any suggestions?
> Sean Dotson, PE
Referenced File... That's what I needed Kathy. Thanks...
Sean Dotson, PE
"KJohnson" wrote in message
news:DE7047AAE78C5C91DD96B54560AE729F@in.WebX.maYIadrTaRb...
> entire assembly.
> Call GetSub(odoc)
> End If
> End If
> Next i
> End Sub
> even
> same
> current
> > project file.
> > Any suggestions?
> > Sean Dotson, PE
No problem.
Kathy Johnson
news:2556D6C642F9E4E85FBA71B3AD434C3D@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > entire assembly.
> > Call GetSub(odoc)
> > End If
> > End If
> > Next i
> > End Sub
click
> > even
> > same
> > current
> > > project file.
> > > Any suggestions?
> > > Sean Dotson, PE
