apprentice & Design view reps
NachoShaw
Advisor Advisor
NachoShaw
Hi
i am opening some assemblies using apprentice invisibly to get data. Can i open these invisibly with specific DesignView Reps? If so, how can i do this?
Nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
Anyone? Come on autodesk. At least help out the users of your application......
Using Apprentice, i am trying to open an assembly with a DesignViewRep. Here is my code-
 Dim oOptions As Inventor.NameValueMap = InventorFunctions._invApp.TransientObjects.CreateNameValueMap
        Call oOptions.Add("DesignViewRepresentation", "WoodFinish")
 Dim GetViewDoc As Inventor.ApprenticeServerDocument = InventorFunctions.m_oServer.OpenWithOptions(FilePath, oOptions)
if i open the file like this-
Dim GetViewDoc As Inventor.ApprenticeServerDocument = InventorFunctions.m_oServer.Open(FilePath)
it works fine which tells me that it is the OpenWithOptions' method that doesnt work. I have taken the construction on the code from the api help... What is not right for this to fail?
Nigel
Nacho
NachoShaw
Any ideas?
Nacho
NachoShaw
ive come to the conclusion that you cannot open a file with a Design View Representation by using OpenWithOptions with Apprentice. There is no physical way of getting it to work. If i open the file without using Apprentice and using OpenWithOptions, it does work but then i cannot get a ClientView as ClientView is ONLY available with apprentice. Soooooo, its yet another function that doesnt work properly and has a contradiction within the API documentation
thanks for nothing Autodesk, you're the best....
Nacho
