Application Visible vs Open Document Invisible Performance
johnster100
johnster100
I'm writing an application that will create drawings in Inventor. I'm trying to increase it's speed and have read that opening documents with visibility set to false will aid in this.
From what I can see there are two ways to make things not visible:
1. Set the application.visible property to false
2. Open the document invisible
Will one of these options perform faster than the other?
I ask because my code has to access browser nodes on the drawings to set some components visiblility so setting the application to false still allows me to do this.
thanks,
John
YuhanZhang
If you deal with Inventor data and need not to interact with UI you can just use invisible mode for both Document and Application. Usually document invisible mode will improve performance better than Application invisible mode.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
