Application.FileOptions.SymbolLibraryPath moved?
Hi community
I was using 'Application.FileOptions.SymbolLibraryPath' in the 2016 API. In 2018 the compiler tells me SymbolLibraryPath is not defined in FileOptions.
In Inventor it is still a part of the 'Application Options - File' dialog. Anyone know if it has been moved in the API?
Cheers
Tore
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Still Application.FileOptions.SymbolLibraryPath is available in Inventor 2018. For more details, refer the below image.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hi Chandra
Tested in VBA and it worked same as for you. Could you please try using .Net (I'm using c#)?
Cheers
Tore
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below c# code to get SymbolLibraryPath. Sample source code is also attached with this post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
bradeneuropeArthur
@Anonymous
What framework version are you using?
What .net version are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
