Application Event: OnOpenDocument
ndillner343SKL
ndillner343SKL
I'm trying to run the rule below upon opening a document. But whenever I open a document, the rule runs twice. How do I make this sub routine only run once within the document being opened?
Private Sub m_ApplicationEvents_OnOpenDocument() Handles m_ApplicationEvents.OnOpenDocument
    Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
    Select Case True
        Case oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject
            MsgBox("Open: I am a Part | " & oDoc.DisplayName)
        Case oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
            MsgBox("Open: I am a Assembly | " & oDoc.DisplayName)
        Case oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject
            MsgBox("Open: I am a Drawing | " & oDoc.DisplayName)
    End Select
End Sub
ndillner343SKL
Never mind, this did the trick.
Private Sub m_ApplicationEvents_OnOpenDocument(ByVal DocumentObject As Inventor._Document, ByVal FullDocumentName As String,
    ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_ApplicationEvents.OnOpenDocument
    If Not BeforeOrAfter = 4098 Then Exit Sub
    Select Case True
        Case DocumentObject.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject
            MsgBox("Open: I am a Part | " & FullDocumentName)
        Case DocumentObject.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
            MsgBox("Open: I am a Assembly | " & FullDocumentName)
        Case DocumentObject.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject
            MsgBox("Open: I am a Drawing | " & FullDocumentName)
    End Select
End Sub
Source:
https://forums.autodesk.com/t5/inventor-programming-ilogic/canceling-the-onopendocument-event-before...
Frederick_Law
You can use EventTimingEnum:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-53FA7C91-113E-44E6-A515-9FBFCA415E35
    If BeforeOrAfter = EventTimingEnum.kAfter Then
        Select Case True
        End Select
End Sub
