API to access DisplayName of the Component associated with a DrawingCurveSegment
Hi All,
I am trying to introduce some automation into a drawing document (.dwg) of an Assembly
The task to accomplish here is to get the displayName (or even Occurrence.Name) of the component, which is represented in the Drawing document by a drawingCurveSegment
A sample program to illustate what my goals would something like this;
Dim objDrawingDoc as DrawingDocument = ThisApplication.ActiveDocument
Dim objCurrentSheet as Sheet = objDrawingDoc.ActiveSheet
Dim objCurveSegment as DrawingCurveSegment
Set objCurveSegment = objCurrentSheet.SelectSet.Item(1)
msgBox "This component is :" & objCurveSegment.????? (something like ReferencedDocumentDescriptor)
I have given it a number of tries, but have not succeeded.
I found a complete sample code which is intended to do the same task in the Help documentation of Inventor (under Create Ballon), but the copied code has failed. (see attachment for error message)
I have also attahced a copy of the same code.
If anyone can give me an idea/clue for this task that would be awsome.
Thanking you.
Wajih
Vladimir.Ananyev
If you need a reference to the component occurrence associated
with the selected drawing curve segment, try the following VBA sample.
Private Sub Component_From_DrawingCurve()
  'create drawing view for assembly document,
  'select some drawing segment
  'and run this macro
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oSheet As Sheet
  Set oSheet = oDoc.ActiveSheet
  ' Set a reference to the drawing curve segment.
  ' This assumes that a drwaing curve is selected.
  Dim oDrawingCurveSegment As DrawingCurveSegment
  Set oDrawingCurveSegment = oDoc.SelectSet.Item(1)
  ' Set a reference to the drawing curve.
  Dim oDrawingCurve As DrawingCurve
  Set oDrawingCurve = oDrawingCurveSegment.Parent
  ' Set a reference to the parent component occurrence
  Dim oOcc As ComponentOccurrence
  Set oOcc = oDrawingCurve.ModelGeometry.ContainingOccurrence
  Debug.Print oOcc.Name & "  is selected."
  Beep
  MsgBox oOcc.Name & "  is selected."
End Sub
 Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thank you Vladimir,
It works brilliantly.
One more thing, how would I cycle through all the DrawingCurveSegments??
This approach is wrong and thus does not work;
Dim oDrawingCurves As DrawingCurvesEnumerator
Set oDrawingCurves = ThisApplication.ActiveDocument.AllReferencedDocuments
But, thank you again for the solution.
Wajih
Oh,
Worked another way,
Dim oDrawingView As DrawingView
Set oDrawingView = ThisApplication.ActiveDocument.selectSet.item(1)
Dim intCurves As Integer
For intCurves = 1 to oDrawingView.DrawingCurves.Count
     Dim oCurve As DrawingCurve
    Set oCurve = oDrawingView.DrawingCurves.(intCurves)
Next
Wajih
Vladimir.Ananyev
Hi Wajih,
Thanks for good news.
For Each - Next loop should work a bit faster (and less code)
For each oCurve in oDrawingView.DrawingCurves
   'do something with oCurve
Next
 Cheers,
Vladimir Ananyev
