API Pack and Go - Error
Jef_E
Jef_E
Hello there,
I'm really bummed. I tried to make a pack and go through the API but it fails and I don't know why.
I followed this sample
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent
        'ensure the first argument of CreatePackAndGo is correct assembly,
        'and the path of the second argument exists
        ' otherwise, the method will crash
        Dim oPacknGo As PackAndGoLib.PackAndGo
        oPacknGo = oPacknGoComp.CreatePackAndGo("C:\temp\source\MyNewPartName.iam", "C:\Temp\Destination")
        ' set the correct project file.  otherwise, the method will crash
        oPacknGo.ProjectFile = "C:\temp\source\webcast.ipj"
        Dim sRefFiles = New String() {}
        Dim sMissFiles = New Object
        '  Set the options
        oPacknGo.SkipLibraries = True
        oPacknGo.SkipStyles = True
        oPacknGo.SkipTemplates = True
        oPacknGo.CollectWorkgroups = False
        oPacknGo.KeepFolderHierarchy = True
        oPacknGo.IncludeLinkedFiles = True
        '  Get the referenced files
        oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles)
        '  Add the referenced files for package
        oPacknGo.AddFilesToPackage(sRefFiles)
        ' Start the pack and go to create the package
        oPacknGo.CreatePackage()
    End Sub
But I get a error on the first line :s
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in mscorlib.dll
Additional information: Retrieving the COM class factory for component with CLSID {F2D4F4E5-EEA1-46FF-A83B-A270C92DAE4B} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
hariharanhZXJ8L
I too have the same problem with Inventor 2022.
with the Exception :
Can some one provide Solution for that ? I have tied to Build my Application in both 64 and 32 as well. but i have the same problem.
HARI.
