API iFeature Table Driven with Custom Column
austen_27_t
Message 1 of 1
austen_27_t
The iFeature is table driven and has one custom column that constitutes the length of the iFeature. I want to also be able to change the length if need be once the iFeature has been inserted. When I run the program the iFeature is inserted with all the proper designated values such as diameter, size, thread, ect... Excluding the length because it is a custom value.
Is there a way where i can make it so it will insert the default value that is in the table but also be able to change the value once the iFeature has been inserted?
Replies (0)
