API for MBD
API for MBD
wgraham
API for MBD
wgraham
Has anyone found a good way to promote dimension constraints to MBD/3DA?  There is a PromoteParameter property associated with the ModelDimensionDefinition, but it doesn't appear to be usable.  The closest thing I've found it so manually select the parameters needed, and execute the built in command.  This doesn't work well from inside one of my commands due to undo/redo requirements and makes managing a individual dimension constraint one at at time really awkward.  Snippet of the best I've been able to make actually work, but as stated earlier undo/redo gets lost.
Dim pdoc as PartDocument
Set pdoc = ThisApplication.ActiveDocument
Dim modeldims as ModelDimension
set modeldims = pdoc .ComponentDefinition.ModelAnnotations.ModelDimensions
Dim i as Integer
Set i = modeldims.Count
pdoc.SelectSet.Set({1+ Dimensions})
Call ThisApplication.CommandManager.ControlDefinitions("3daPromoteDimensionCmd").Execute
for j = i+1 to modeldims.Count
    Dim newannotation = modeldims(j)
    {Do something with newannotation}
next
Wouldn't expect it to be quite this painful to convert a dimension to model annotation.  One help would be appreciated.
William Graham
Hello mr Graham,
I have recently done the same thing, but sadly in a way more complicated method. While my method did not require the usage of commands, I pretty much created a new Annotation on the same entities on which the sketch dimension was created. It works, but for every type of sketch dimension constraint, a seperate handler for the annotation had to be created. (like diameter constraint to diametermodeldimension annotation).
However, I can help you a bit with your undo issue. By using the transactionmanager, you can make the code run as one single undo action. This works like this (in VBA):
sub yourFunction()
   Dim oTrans as Transaction
   set oTrans = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "just some name")
   On Error Goto ErrorHandler
   'place here your code, or at least all action related code
   'make sure you do NOT call Exit sub here
   Call oTrans.end
   Exit sub
ErrorHandler:
   Call oTrans.abort
end sub
 Special warning here: you MUST either end or abort the transaction in this routine, hence the reason I included an error handler in the code. if this is not done, your instance of inventor will pretty much crash. Hence the reason why you cannot use exit sub without calling oTrans.end first. if this does happen somehow, you can still write a new function and use this line:
Call thisapplication.transactionmanager.currenttransaction.abort
To save your work.
Hope this helped,
Peter Verheijen
wgraham
Peter,
Thanks for the reply.  I was aware of the transaction option, but it doesn't play well with my overall coding plan.  Initiating a new command while a change request is in progress cancelling the current command.  For what it's worth, below is a recap of what I figured out late yesterday to make things work.  Essential steps are as follows.
  1.  Create ModelDimensionDefinition(Linear, Diameter, Angle)
  2.  Add PromoteParameter to definition (must occur before adding as modeldimension)
  3. Add definition and modeldimension
Strangely enough, started creating independent model dimension rather than promoting sketch/model parameters.  Noticed that if a sketch parameter is promoted the ability to change annotation planes and pull into a different drawing view is fairly limited.  The most robust way to make it work fairly independently is attached work points to sketch points and attach 3D model annotations to the work points.  This allows work points to be redefined to new locations with out losing the reference.  It's a fairly heavy handed work around, to get the best of 3D and 2D annotation, but it works.
William Graham
