API - Compile error with DrawingView
lian_xie
lian_xie
Hello There,
I was trying to test something on the drawing document with VBA and found an error today wtih "DrawingView" object with Inventor 2014 (as shown in the attached word file).  The same code worked fine with Inventor 2017.
Since I need to support Inventor 2014 for a while and would like to have this problem solved.
Thanks, Lian
wayne.brill
Hi Lien,
The DrawingView object has been in the Inventor API for many releases before Inventor 2014. (first available in Inventor Version 4)
It seems like there is something in that project that is causing it. Can you try adding the Inventor namespace?
Dim oDrwView As Inventor.DrawingView
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
lian_xie
Thanks for the quick reply.
The solution worked well.
Thanks, Lian
