API - Close drawing when string matches
This should close the drawing when sting matches. I dont know why this doest work. Tested it with other value, its fine.
Dim oFileDlg As Inventor.FileDialog = Nothing
ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Autodesk Inventor Drawings (*.idw)|*.idw"
oFileDlg.DialogTitle = "Select Drawings To Check"
oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oFileDlg.MultiSelectEnabled =True
oFileDlg.FilterIndex = 1
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
Dim oDrgDoc As DrawingDocument
If Err.Number <> 0 Then
	MsgBox("File not chosen.",,"Dialog Cancellation")
ElseIf oFileDlg.FileName <> "" Then
	For Each oFileName As String In oFileDlg.FileName.Split("|")
		oDrgDoc = ThisApplication.Documents.Open(oFileName)
		doc = ThisApplication.ActiveDocument
		oDwgName = IO.Path.GetFileNameWithoutExtension(oFileName).ToUpper
		'MsgBox(oDwgName)
		Dim oFD As FileDescriptor
		oFD = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
		oModelRef = (oFD.FullFileName.Split("\").Last()).Split(".").First().ToUpper
		'MsgBox(oModelRef)
		'Test
'			DwgName = "one"
'			oModelRef = "one"
		If DwgName = oModelRef  Then
			oDrgDoc.Close(True)
			oDrgDoc.ReleaseReference
	Next
JhoelForshav
Hi @Anonymous
To compare you use the variable "DwgName", this is never declared. I suppose you just missed an "o"?
So it should be:
If oDwgName = oModelRef  Then
			oDrgDoc.Close(True)
Insted 🙂
OMG! Thank you @JhoelForshav
