Any Sub-Contract Programmers to write a "Addin" for Inventor?
isocam
isocam
Can anybody help??
I need an "addin" writing, for "AutoDesk Inventor" to run a VBA macro on either "SAVE" or "CLOSE" of a ipt, idw or iam file.
Is anybody interested in wirting the program for me?
If so can you please give me an indication of cost???
Thanks in advance!!!
Darren
Hello isocam,
I regularly write addins for companies.
Could you mail me a bit more details? info AT cadkunde DOT nl
Then I can be more specific about the costs
Kind Regards,
Arnold van der Veen
matt_jlt
If you want to look into doing it yourself (the tutorials are fairly straight foreward) , it's pretty much done for you on Brian Ekins blog
http://modthemachine.typepad.com/my_weblog/2013/07/add-in-with-event-example-to-replace-auto-run-mac...
Also, depending on the version of inventor you are running, this could be done very easily by using an external iLogic rule that runs a macro for you, I would recommend this as you are able to maintain / change the code yourself.
InventorVb.RunMacro("projectName", "moduleName", "macroName")
I think someone has already made an addin that allows you to choose macros to autorun. Cant remember where it is or what it was called so not very helpful, but I know it out in the internet somewhere 😉
If you really want an addin, let me know and I might be able to make one for you if you are using Inventor 2014/2015. Should only take a few minutes If it's just an autorun.
Regards, Matt.
