Any script to label corners of model in oaoer space ?
hello everyone
is there any script (maybe trick in inv 2010 how to achive this) which can label selected points this way (in paper space):
< Xcoord , Ycoord, Zcoord >
now i export 3d model to autocad and then use lisp macro. but it is really time consuming.
when model is updated i need to do this again 😞
thanks
romek
xiaodong_liang
Autodesk Support
Autodesk Support
I am not sure if it helps, could you take a look at this post?
http://adndevblog.typepad.com/manufacturing/2012/05/create-leadernote-which-is-constrained-with-one-...
i'm totaly beginner with inv VBA. I don't know if there is something wrong on page or should i change something but original code not working. i made these modification:
Sub AddLeaderNoteWithHoleCenter()
    ' assumes you have had Inventor application
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' get curve, assume a hole curve is selected
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Set oDrawingCurveSegment = oDrawDoc.SelectSet(1)
    Dim oDrawingCurve As DrawingCurve
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    ' get center point
    Dim oMidPoint As Point2d
    Set oMidPoint = oDrawingCurve.CenterPoint
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 5, oMidPoint.Y + 5))
    ' Create geometry intent from center point
    Dim oGeometryIntent As GeometryIntent
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oMidPoint)
    Call oLeaderPoints.Add(oGeometryIntent)
    Dim sText As String
    sText = "Leader Note for one hole center"
    ' add leader note
    Dim oLeaderNote As LeaderNote
    Set oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
End Sub
now works fine Smiley Happy there is a lot of information in this code.
will see if i will be able to revise to fint into my needs
Last question. I can get XYZ coords of model but is it possible to create link ("inteligent leader") between model and paper leader so when model change then leader update ? or i can only use this to describe corner but without link ?
thank you very mych Xiaodong. this is a really big help.
regards
romek
xiaodong_liang
Autodesk Support
Autodesk Support
Hi adservco,
firstly, i am glad to hear you got some worked code : -)
about "inteligent leader", what kind of update you required. e.g.
- if the leader lines would update with the curve changing
- if the text of the leader can change with the model changing.
- others?
since the leader is created from the curves intent CreateGeometryIntent, the leader lines should update automatically if the drawing curve updates because of the changing of model. But about text, I am afriad you need to watch the model changing event and look for the leader and update the text with the new content. Of course, you could also just provide a button in the drawing, and ask your user to remember to click it to get the latest status. This will save your more time to work out a nice workflow with event.
1. let say i shown plan view of my model (paper space).
2. now i want to select point on my model and get X,Y,Z coordinates. (put leader with text)
3. when model change, move up, down, left, right then all X,Y, Z values are change
"inteligent leader" should update X,Y,Z text after 3d model changes.
thanks
romek
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry for the delay.
- if what you need is: when the model changes, the leader text can be changed automatically, you may have to start the DrawingViewEvents.OnViewUpdate and check whether the model is changed and update the text
- if it is fine with you to ask your user to click a button to execute update, you could just get the model (feature) information  and update it.
In either case, you will need to get the model (feature) the leader attaches to. I happened to write a small code on it. Probably it could be a little help for you.
http://adndevblog.typepad.com/manufacturing/2013/04/get-model-document-from-leadernote.html
really good example. i will try to combine all gathered informatiom and see where it takes me
thanks again
