Another Inventor API bug
BugFinder
BugFinder
I am trying to use the OnFileresolution event to resolve files and so far this is what I have:
Option Explicit
Private WithEvents inv As Inventor.FileAccessEvents
Private invApp As Inventor.Application
Private Sub Class_Initialize()
    On Error Resume Next
    Set invApp = GetObject(, "Inventor.Application")
    If Err Then
        Err.Clear
        Set invApp = CreateObject("Inventor.Application")
        invApp.Visible = False
    On Error GoTo 0
    Set inv = invApp.FileAccessEvents
End Sub
Private Sub inv_OnFileResolution(ByVal RelativeFileName As String, ByVal LibraryName As String, CustomLogicalName() As Byte, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, FullFileName As String, HandlingCode As Inventor.HandlingCodeEnum)
    Dim str As String
    HandlingCode = kEventHandled
    If (BeforeOrAfter = kBefore) Then
        str = "C:\New folder\"
        FullFileName = str & RelativeFileName
End Sub
 The problem is the Handlingcode does nothing.  Event though it is set to handled, I still get a dialog box asking for the file which I have specified in the FullFileName.
Anyone else got this? Smiley Frustrated
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi BugFinder,
I tried to reproduce your issue and was faced with the same problem in VB.net 2010.
It seems that this is related to an MS issue. More information you can find here:
http://social.msdn.microsoft.com/Forums/eu/clr/thread/a312244e-371c-4435-a21c-89e604a670d0
After I changed the value for Embed Interop Types in VB.net to False the issue was gone.
Then the file resolution will accept your FullFileName and you can redirect to another file.
Could you please test and give us a feedback.
Thanks.
Dennis
Dennis Ossadnik
Senior Technical Support Specialist
BugFinder
Hi Dennis,
Sorry I forgot to say, I was using VBA in Access.  Do you know of an appropriate fix for that?
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi BugFinder,
I checked this on my machine and it works. I can handle the event properly using VBA in Access.
(Inventor 2012 - Access 2010)
But maybe the following could cause the confusion:
The RelativeFileName could contain also the relative path to the file. If the FullFileName you assembled in your code does not exist, Inventor will show the standard file resolution dialog.
I stepped in this trap while testing the code.
For instance:
The RelativeFileName is "Test\file1.ipt" and you want to redirect to the folder "C:\New folder\" then this would end in "C:\New folder\Test\file1.ipt".
But if your file is in "C:\New folder\" Inventor will show the standard dialog and it "seems" that nothing happend.
I changed the code to check if there is a relative path and check afterwards if the file exist.
Maybe you could give it a try:
        Dim FileName As String
        Dim NewFullFileName As String
        Dim str As String
        NewFullFileName = str & RelativeFileName
        'relative path?
        If InStr(1, RelativeFileName, "\") > 0 Then
            If MsgBox("Your RelativeFileName [" & RelativeFileName & "] contais a relative path. Do you want to use only the FileName instead?", vbYesNo) = vbYes Then
                FileName = Right(RelativeFileName, Len(RelativeFileName) - InStrRev(RelativeFileName, "\"))
                NewFullFileName = str & FileName
        'Check if the file exists
        Dim objFSO As Object
        Set objFSO = CreateObject("scripting.filesystemobject")
        If objFSO.FileExists(NewFullFileName) = False Then
            MsgBox ("File [" & NewFullFileName & "] not found! Event OnFileResolution will not be handled in this step.")
        Else
        'Only if the check is okay, then set the handling code
            FullFileName = NewFullFileName
        objFSO = Nothing
End Sub
Dennis
Dennis Ossadnik
