Alt+Enter Excel Values combine into a single line
AMN3161
AMN3161
Hello
Is there a quick way to use logic to take multiple values in a excel cell that were Alt+Enter'ed and combine them into a single line? then populate a iproperty with it?
Could you give more info?
If your cell value is:
AAA
BBB
CCC
Do you want your iporperty to be AAABBBCCC or something else? (AAA-BBB-CCC, AAA BBB CCC)
Do you want to copy it to one single iproperty? Which one?
AMN3161
I would prefer to have spaces if that the easiest route
So if its
AAA
BBB
CCC
I want the iproperty to be AAA BBB CCC
Dim CellValue As String = GoExcel.CellValue("YourExcelFilePathAndFilename", "SheetName", "CellAdress e.g. A1")
Dim StrArray As Object
Dim StrResult As String = ""
StrArray = Split(CellValue,vbLf)
For i = LBound(StrArray) To UBound(StrArray)
	If StrResult = "" Then
		StrResult = StrResult & StrArray(i)
	Else
		StrResult = StrResult & " " & StrArray(i)
Next
iProperties.Value("Summary", "Title") = StrResult
That is for Title property. For another iproperties just change last line
AMN3161
Should of mentioned its for a find row but some tweaking and it works beautifully
GoExcel.TitleRow = 10
GoExcel.FindRowStart = 11
i = GoExcel.FindRow(iProperties.Value("Custom", "Project_BOM"), "BOM", "Manufacturer Part No.", "=", iProperties.Value("Project", "Part Number"))
If i = -1
iProperties.Value("Project", "Stock Number") = "This Part Number is number is not in the Project BOM"
Else
Dim CellValue As String = GoExcel.CurrentRowValue("P&ID Tag(s)")
	Else
Next
iProperties.Value("Project", "Stock Number") = StrResult
Thank you so much!
