All View Representations to Default - how to run it in all subassemblies
G.DeGheest
G.DeGheest
I have an iLogic code that works on all assemblies in the Main Assembly.
And I want to make it work in all the Assemblies and Subassemblies also. But I don't know how.
Can anyone help me to adjust the code?
Dim doc As AssemblyDocument = ThisDoc.Document
Dim cdef As ComponentDefinition = doc.ComponentDefinition
Dim occ As Inventor.ComponentOccurrence
For Each occ In cdef.Occurrences
	Try
	occ.SetDesignViewRepresentation("Default", True, True)
	Catch
	End Try
Next
Cadkunde.nl
You can try this:
Sub Main()
TraverseAssembly(doc.ComponentDefinition.Occurrences, 1)
doc.activate
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
	For Each occ In Occurrences
		If occ.suppressed = False Then
			If occ.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
				Try
				Catch
				End Try
				Dim occdoc As AssemblyDocument = occ.Definition.Document
				ThisApplication.Documents.Open(occdoc.FullFileName, False)
				TraverseAssembly(occdoc.ComponentDefinition.Occurrences, Level + 1)
				ThisApplication.Documents.ItemByName(occdoc.FullFileName).close
	Next
End Sub
Not sure if you need to activate the assembly and open with visible = true
Also this disregards any levelofdetails
Using how to iterate through assembly from: https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
G.DeGheest
I just tested your code and it works great. Thank you so much for your professional feedback!
This code will save me a lot of time!
