All SubAssembly Part QTY export to each part Ilogic as Custom Parameter
vkulikajevas
vkulikajevas
IS there a way to make a rule, which export SubAssembly component QTY and create Custom iProperty for each?
For example in Assembly01, there are 6 Parts: 4 x Part A and 2 x Part B.
The rule should make an Custom iProperty for each Part A and Part B with Custom Property named "iQTY" = Qty in assembly.
Part A would have Custom iProperty "iQTY = 4"
Part B would have Custom iProperty "iQTY = 2"
Also if there is Subassebly in main assembly, it might also create a iQTY for it too.
Sergio.D.Suárez
Hi, try the next rule driven from the master assembly.
Sub Main
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewEnabled = True
oBOM.PartsOnlyViewEnabled = True
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item(3) ' Parts Only
Dim oBOMRowPO As BOMRow
For Each oBOMRowPO In oBOMViewPO.BOMRows
	On Error Resume Next
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRowPO.ComponentDefinitions.Item(1)
	Dim CompFileNameOnly As String
    CompFileNameOnly = oCompDef.Document.Displayname
    'MessageBox.Show(CompFileNameOnly)
    Dim Qty As String
    Qty = oBOMRowPO.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "iQTY") = Qty
Next
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item(2)   'Structured
Dim oBOMRowStruc As BOMRow
Dim arrSubAssemblyList As New ArrayList
Call QueryBOMRowProperties(oBOMViewStruc.BOMRows, arrSubAssemblyList, 1)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, arrSubAssembly As ArrayList, oParentQty As Integer)
Dim i As Long
For i = 1 To oBOMRows.Count
    Dim oBOMRowStruc As BOMRow = oBOMRows.Item(i)
    Dim oCompDef As ComponentDefinition = oBOMRowStruc.ComponentDefinitions.Item(1)
    Dim oQty As Integer
    If TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
            oQty = oBOMRowStruc.ItemQuantity * oParentQty
            Dim additionalQty As Integer
            If arrSubAssembly.Count <> 0 Then
                Dim counter As Integer = 0
                For Each CompData As String In arrSubAssembly
                    Dim commaindex As Integer = CompData.IndexOf(":")
                    Dim CompName As String = CompData.Substring(0,commaindex)
                    If CompName = CompFileNameOnly Then
                        additionalQty = CompData.Substring(commaindex+1)
                    Else
                        counter += 1
                Next
                If additionalQty = 0 Then
                    arrSubAssembly.Add(CompFileNameOnly & ":" & oQty)
                Else
                    arrSubAssembly(counter) = CompFileNameOnly & ":" & oQty + additionalQty
            Else
            iProperties.Value(CompFileNameOnly, "Custom", "iQTY") = oQty + additionalQty
            'Recursively iterate child rows if present.
            If Not oBOMRowStruc.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oBOMRowStruc.ChildRows, arrSubAssembly, oQty)
    Next
End Sub
 I hope this helps with your problem. Grettings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
vkulikajevas
Thank you for quick response, Sergio D. Suarez!
I tried using this code on master assembly.
No part received the parameter iQTY.
I am not sure where is the problem. I didn't get any error messages as well.
Maybe code could somehow link BOM parts list with the iQTY?
Because it is possible to view all part quantities there.
Maybe the code could link the part number and QTY and create the iQTY for each part?
Sergio.D.Suárez
Try the following rule. Sometimes the inventor's language can give some problems to access the BOM.
Sub Main
Dim doc As AssemblyDocument= ThisDoc.Document
Dim oValueList As New ArrayList
For Each oBOMView As BOMView In oBOM.BOMViews
    oValueList.Add(oBOMView.Name)
Next
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item(oValueList(2)) ' Parts Only
For Each oBOMRowPO As BOMRow In oBOMViewPO.BOMRows
    Dim Qty As String
Next
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item(oValueList(1))   'Structured
End Sub
Dim i As Long
    Dim oQty As Integer
                    Else
                        counter += 1
                Next
                Else
            Else
    Next
End Sub
 I hope this solves the problem. Regards
Mechanical Designer
vkulikajevas
Hello, Sergio D Suarez, unfortunately the second code does not work too.
Maybe the code could create excel file and associate the number with  parts?
Copy iQTY to each part and then delete created excel file"?
I think then it should run more smoothly
vkulikajevas
Managed to find and edit this code to work as needed! Maybe someone will also find this useful!
Sub Main
    If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject Then MsgBox("Rule only valid in assembly files!"): Exit Sub
    If ThisDoc.Document.FullFileName = "" Then MsgBox("GA Not Saved yet!" & vbLf & vbLf & "Aborting!"): Exit Sub
    Dim oGADoc As AssemblyDocument
    oGADoc = ThisDoc.Document
    BatchQTY = InputBox("ENTER TOTAL QTY REQUIRED OF GA", "GA QTY", "")
    iProperties.Value("Custom", "iQTY") = BatchQTY
    Dim oBOM As BOM
     oBOM = oGADoc.ComponentDefinition.BOM
    With oBOM
    End With
    Call PurgeBatchQTY(oGADoc)
    Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item("Parts Only")
    Call SetBatchPartQTYs(oBOMViewPO, BatchQTY)
    Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item("Structured")
    Call SetBatchAssemblyQTYs(oBOMViewStruc.BOMRows, BatchQTY)
End Sub
Sub PurgeBatchQTY(oDoc As Document)
    For Each oSubDoc in oDoc.AllReferencedDocuments
        If oSubDoc.IsModifiable = True Then
            iProperties.Value(System.IO.Path.GetFileName(oSubDoc.FullFileName), "Custom", "iQTY") = 0
    Next
End Sub
Sub SetBatchPartQTYs(ByVal oBOMViewPO As BOMView, ByVal BatchQTY As Integer)
        oRowDoc = oCompDef.Document
        Dim Qty As Integer = oBOMRowPO.TotalQuantity
        If oRowDoc.IsModifiable = True Then
            iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "iQTY") = Qty * BatchQTY
    Next
End Sub
Private Sub SetBatchAssemblyQTYs(oBOMRows As BOMRowsEnumerator, oParentQty As Integer)
    Dim oQty As Integer
    For Each oBOMRowStruct In oBOMRows
        oCompDef = oBOMRowStruct.ComponentDefinitions.Item(1)
        'Single line Check + Continues:
        If Not (TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure) Then Continue For
        If oRowDoc.IsModifiable = False Then Continue For
        'Resume functionality
        oQty = oBOMRowStruct.ItemQuantity * oParentQty
        iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "iQTY") = oQty + iProperties.Value(System.IO.Path.GetFileName(oRowDoc.FullFileName), "Custom", "iQTY")
        If Not (oBOMRowStruct.ChildRows Is Nothing) Then
            Call SetBatchAssemblyQTYs(oBOMRowStruct.ChildRows, oQty)
    Next
End Sub
samA3NNH
This code is really great, can you get it to work for model states?
