all my macros are dead
Message 1 of 9
Just happened to day. I can not run any of my macros.
Try to open the codes and nothing appears.
Anyone know what is going on here
Replies (8)
Message 2 of 9
Well, if they were working before, the first place I would check would be
the paths to be sure they have not changed.
Joe
"Chris" wrote in message
news:4927288@discussion.autodesk.com...
Message 3 of 9
The paths are unchanged. Now I cannot edit the .ivb files also.
Anyone here helps pls.
"Joe Sutphin" wrote in message
news:4927313@discussion.autodesk.com...
Joe
Message 4 of 9
anyone please. I need my macros back very bad
thx
Message 5 of 9
1. Are all your macros in your "default.ivb" file?
2. What is your Tools->Application Options->File->Default VBA project set to?
3. Does the file listed in #2 actually exist in the location specified? Do you keep a
backup copy of it? I t may have become corrupted. When was it last modified by
you or someone else? DOes the modification time in Explorer match what you
remember as being the last time edited?
4. What exactly happens when you execute Tools->Macros->Visual Basic Editor?
Does the editor come up at all? If it comes up with No macros loaded, have you
tried loading a Project in it (VBA editor macro files are "Projects").
5. Do you have Mr. Macro add-in loaded? If not, you may consider getting it.
6. Are the macro files located on a network drive? Are they shared by other users?
There used to be a problem with that setup, not sure if it is fixed yet. How is the
network throughput?
"Chris" wrote in message news:4927544@discussion.autodesk.com...
thx
Message 6 of 9
1. Are all your macros in your "default.ivb" file? Yes
to? is set ot default.ivb
you keep a
by
remember as being the last time edited? It worked fine yesterday and I did
not change any of them of a while.
you
Nothing appear.
I do have it.
users?
is the
network throughput? Local only. Noone else access to these files except me
thx
Message 7 of 9
Have you tried cleaning out temp files and rebooting?
Can you run the macros with Mr. Macro at all?
If after rebooting, the VBA editor still fails to come up and
you can not run the macros using Mr. Macro, you MIGHT try
renaming your default.ivb file TEMPORARILY (only on disk, do not change
you application options), then see if the VBA editor comes up after restarting Inventor.
"Chris" wrote in message news:4927565@discussion.autodesk.com...
you keep a
by
you
Nothing appear.
I do have it.
users?
is the
thx
Message 8 of 9
Don't you have a second Inventor process running? Happens to me when IV
crashes and I start again without killing the first IV process in the
taskmanager. Even my plugins are disabled by then.
> you keep a
> by
> you
> Nothing appear.
> I do have it.
> users?
> is the
> thx
> Thanks
Message 9 of 9
actually I already restarted the computer few times
"JakeNL" wrote in message
news:4927780@discussion.autodesk.com...
> you keep a
modified
> by
Editor?
> you
> Nothing appear.
it.
> I do have it.
other
> users?
How
> is the
> thx
> Thanks
