Aligning 2 dimensions
Hi all,
How can I fix 2 different dimensions to align each other? When I run my drawing automation application, these 2 dimensions dancing apart which must be stick together. It is very easy to adjust the position when I create a drawing one by one manually but I don't know how to solve this problem when I cannot do it manually while running a program. Thanks in advance for your help!
JhoelForshav
Hi @Anonymous
I assume you can retrieve the objects (LinearGeneralDimension) of these two dimensons in your drawing automation code?
Then it's just q question of aligning the text origins for the dimensions - In this case give them the same Y-value.
Here's an example:
Dim oSheet As Sheet = ActiveSheet.Sheet
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oDim1 As LinearGeneralDimension = oSheet.DrawingDimensions.GeneralDimensions.Item(1)
Dim oDim2 As LinearGeneralDimension = oSheet.DrawingDimensions.GeneralDimensions.Item(2)
Dim pt1 As Point2d = oDim1.Text.Origin
Dim pt2 As Point2d = oDim2.Text.Origin
Dim pt3 As Point2d = oTG.CreatePoint2d(pt2.X, pt1.Y)
oDim2.Text.Origin = pt3
@JhoelForshav Thank you for your constant help!
Yes, this whole view is quoted by "Retrieve Model Annotations".
In your code, seems like that it assumed that there are only 2 dimensions. What if I have multiple dimensions in the drawing? How can I select out the only 2 dimensions that I want to fix together?
JhoelForshav
Hi @Anonymous
As I said I thought that you already had a way to get the dimensions objects. But now I understand.
Since the dimensions are retrieved, we could use the parameter name of the dimension in the model to get them.
In this example the parameter names in the model for the two retrieved dimensions are d6 and d7.
Hope it helps 🙂
For Each oDim As GeneralDimension In oSheet.DrawingDimensions.GeneralDimensions
	If oDim.Retrieved
		If oDim.RetrievedFrom.Parameter.Name = "d6" Then oDim1 = oDim
		If oDim.RetrievedFrom.Parameter.Name = "d7" Then oDim2 = oDim
	If oDim1 IsNot Nothing AndAlso oDim2 IsNot Nothing Then Exit For
Next
