After update (2022 to 2024) Ilogic is updating without trigger.
jocean_vieiraZ9YQS
jocean_vieiraZ9YQS
Good morning
We just recently updated from 2022 to 2024 and Ilogic is updating without trigger. Before it would just run manually (as we intended) but now they are being saved with an apparent random trigger or when saved.
What should I do? change all the external rules to add a condition before the code?
WCrihfield
Hi @jocean_vieiraZ9YQS.  You may have already checked this, but just in case...go to your Manage tab, then go to the iLogic panel, and click on the Event Triggers button.  In that dialog are multiple tabs along the top.  Check within each one of them to see if there are any iLogic rules listed under any of the event names on the right.  The settings on the tab named "This Document" will only effect that one document, and those settings are actually saved within that one document, but the settings on all the other tabs are saved within an external XML file, because they can potentially effect every document, or every document of a certain type.  If you see any rules listed on any of those tabs that you believe should not be there, then you should probably remove them from the list on the right.  That may stop some, if not all of the 'triggering'.  You may already know this too, but if any document has any internal (saved within that document) iLogic rules in them, and those rules contain any blue, unquoted parameter names, then whenever the value of any of those blue parameters changes, that will automatically trigger that rule(s) to run.  There are multiple ways to stop that too, if needed.
Wesley Crihfield
(Not an Autodesk Employee)
