Adjustments to code which contains all items to one plane
will.wells
will.wells
Could anyone help with changing this code that contains all items to the XY plane and change it to work plane 1
@Curtis_Waguespack
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPlane As WorkPlane
Dim oProxyPlane As WorkPlaneProxy
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	'check for and skip virtual components
	'(in case a virtual component trips things up)
	If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
    	oPlane = oOccurrence.Definition.WorkPlanes.Item(3) 'Work Plane4
		'create component proxy plane in assembly
   		Call oOccurrence.CreateGeometryProxy(oPlane, oProxyPlane)
	'get assembly plane
	Dim oPlane2 As WorkPlane
	oPlane2 = oAsmCompDef.WorkPlanes.Item(3) 'Work Plane4
	' Create the constraint using the work plane proxies.
    Call oAsmCompDef.Constraints.AddFlushConstraint(oProxyPlane, oPlane2, 0)
Next
Thank you
Curtis_Waguespack
Hi @will.wells ,
This appears to be a version of this example, which used the work plane collection item number to specify the planes. I'm not sure why I did it that way at the time, but to update this you should be able to provide the plane names as strings in quotes as shown.
Post back if this does not answer the questions.
Hope that helps,
Curtis
    	oPlane = oOccurrence.Definition.WorkPlanes.Item("XY Plane")
	'get assembly plane
	oPlane2 = oAsmCompDef.WorkPlanes.Item("Work Plane1")
Next
In my test I had Work Plane1 in the assembly, and just used the XY plane in the parts
will.wells
Very much appreciate the help the solution worked
