I can't remember how I did this before and no longer have the files to try and figure it out.
I have a part that is comprised of a sketch that is used to drive frame generator components.
I have linked the parameters from the part file to the assembly that contains the frame generator components, but I can't edit the parameters, they are greyed out.
I used to have an assembly that was driven the part file parameters and a form prompt where I could change the parameters and it would update.
I want to be able to edit the Height parameter. I seem to recall this was done using a simple iLogic rule but I can't remember...
Sean Farr
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
Inventor 2016 SP1
Dell Precision 3660
