AddSelectionFilter Feature Dimensions
Hello.
I use VB6 with Inventor 10
I want the user to select a dimension inside a part through API .
This is a Sketch Dimension or a Extrude Dimension.
For Sketch Dimensions I use kSketchDimConstraintFilter
But then I can't select the Extrude (Feature) dimensions.
Can this somehow be done?
Thanks in advanced,
Geert
Code:
Dim oSelect As New clsSelect
Dim oDimension As Inventor.DimensionConstraint
Set oDimension = oSelect.Pick
(kSketchDimConstraintFilter, "Select length!")
-> Pick is a class functie inside clsSelect:
Public Function Pick(filter As SelectionFilterEnum, strTekst As String) As Object
Set oSelect = oInteraction.SelectEvents
oSelect.AddSelectionFilter filter
etc......
Sorry, but the API currently does not support selection of feature
dimensions. This is a known limitation and will be considered for a future
release.
Sanjay-
wrote in message news:5091613@discussion.autodesk.com...
Hello.
Thanks in advanced,
Geert
Code:
As Object
etc......
Thanks for your reply Sanjay.
I can stop searching now and hope its in V11
Geert
Hi Sanjay.
We now have Inventor 11, but I still can't find it.
Is this still a limitation?
Geert van den Brand
Unfortunately, yes. The API doesn't yet support feature dimensions (other
than being able to get to the associated parameter).
Sanjay-
wrote in message news:5161897@discussion.autodesk.com...
Hi Sanjay.
Geert van den Brand
