AddInsertConstraint
AddInsertConstraint
mario170979
AddInsertConstraint
mario170979
at first i have not so much experience in programming that why here in this case i have no idea. We use from a previous colleagues a script which has the function: in a assembly we have different parts a: tubes b: ubends. the you select a ubend and than the edges of 2 tubes and you get 2 constraints. helpful is that a copy of the ubend is placed.
But now we have to constrain in the same assembly simple tubes too. Which takes by hand a lot time.
maybe somebody has a idea how to get a script which works like the actual but for 1 constraint only (circular to circular) with benefit that we have a loop like in the actual script.
our actual code:
Sub Main()
Dim Uname As String
Uname = "B_"
Dim ConstraintDirection As String
ConstraintDirection = "True"
Dim nx, ny, nz, ox, oy, oz As Double
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
Dim oBody As SurfaceBody
1:
oBody = ThisApplication.CommandManager.Pick(kPartBodyFilter, "Pick U-Bend")
  If oBody Is Nothing Then
     Exit Sub
   If Left(oBody.Parent.Name, 2) <> Uname Then
      GoTo 1
On Error Resume Next
Dim occ As ComponentOccurrence
occ = oAsmCompDef.Occurrences.ItemByName(oBody.Parent.Name)
If occ.Constraints.Count > 0 Then
'Debug.Print "Constrainted"
GoTo 1
If Err.Number <> 0 Then
	Debug.Print(Err.Number, Err.Description)
'Original Code: Debug.Print Err.Number; Err.Description
     On Error GoTo 0
   '  MsgBox "Exit from procedure / ESC.."
     Exit Sub
Dim part As PartDocument
part = ThisApplication.Documents.ItemByName(occ.ReferencedDocumentDescriptor.FullDocumentName)
'Debug.Print "Full Document Name: " & part.FullDocumentName & vbCrLf & "Document Name: " & part.DisplayName
 Dim oPath As String
 oPath = part.FullDocumentName
    Dim oTransform As Matrix
    oTransform = occ.Transformation
    Dim oOrigin As Point
    Dim oXAxis As Vector
    Dim oYAxis As Vector
    Dim oZAxis As Vector
    Call oTransform.GetCoordinateSystem(oOrigin, oXAxis, oYAxis, oZAxis)
    Dim vZ As Vector
    Dim vX As Vector
    Dim vY As Vector
    vX = oTG.CreateVector(1, 0, 0)
    vY = oTG.CreateVector(0, 1, 0)
    vZ = oTG.CreateVector(0, 0, 1)
    Dim oUOM As Inventor.UnitsOfMeasure
    oUOM = oAsmCompDef.Parent.UnitsOfMeasure
    nx = oOrigin.X
    ny = oOrigin.Y
    nz = oOrigin.Z
Do
    Call oMatrix.SetTranslation(oTG.CreateVector(nx, ny, nz))
Dim f As Edge
Dim fp As EdgeProxy
Dim oc As ObjectCollection
oc = ThisApplication.TransientObjects.CreateObjectCollection
    For Each f In occ.SurfaceBodies.Item(1).ConvexEdges
        Call occ.CreateGeometryProxy(f, fp)
        oc.Add (fp)
    Next
   Dim iOcCount As Long
   iOcCount = oc.Count
   Dim oEdge1 As Edge
   Dim oEdge2 As Edge
   Dim oEdge3 As Edge
   Dim oEdge4 As Edge
  oEdge1 = oc(1)
  oEdge2 = oc(iOcCount)
   oEdge3 = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Select the Circular Edge 1.")
   oEdge4 = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "Select the Circular Edge 2.")
    Dim oInsert As InsertConstraint
    oInsert = oAsmCompDef.Constraints.AddInsertConstraint(oEdge1, oEdge3, ConstraintDirection, 0)
     On Error GoTo 0
     Exit Sub
     oInsert = oAsmCompDef.Constraints.AddInsertConstraint(oEdge2, oEdge4, ConstraintDirection, 0)
     On Error GoTo 0
     Exit Sub
    If oInsert.HealthStatus = 11786 Then
              occ.Delete
 occ = oAsmCompDef.Occurrences.Add(oPath, oMatrix) 'Place part
ThisApplication.ActiveDocument.Rebuild
Loop
End Sub
MR
Autodesk Inventor Professional 2025
Autodesk Vault Professional 2025
JelteDeJong
Hi is this what you need?
Dim ConstraintDirection As String = "True"
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oMatrix As Matrix = oTG.CreateMatrix
Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
Dim oBody As SurfaceBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick U-Bend")
If oBody Is Nothing Then Exit Sub
Dim occ As ComponentOccurrence = Nothing
Try
Catch ex As Exception
    Exit Sub
End Try
Dim part As PartDocument = ThisApplication.Documents.ItemByName(occ.ReferencedDocumentDescriptor.FullDocumentName)
Dim oPath As String = part.FullDocumentName
Dim oTransform As Matrix = occ.Transformation
Dim vZ As Vector = oTG.CreateVector(1, 0, 0)
Dim vX As Vector = oTG.CreateVector(0, 1, 0)
Dim vY As Vector = oTG.CreateVector(0, 0, 1)
nx = oOrigin.X
ny = oOrigin.Y
nz = oOrigin.Z
Do
    Dim oc As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
    For Each f As Edge In occ.SurfaceBodies.Item(1).ConvexEdges
        Dim fp As EdgeProxy
        oc.Add(fp)
    Next
    Dim iOcCount As Long = oc.Count
    Dim oEdge1 As Edge = oc(1)
    Dim oEdge2 As Edge = oc(iOcCount)
    Dim oEdge3 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select the Circular Edge.")
    Try
        Exit Sub
    End Try
            occ.Delete()
    ThisApplication.ActiveDocument.Rebuild()
Loop
Jelte de Jong
Blog: hjalte.nl - github.com
mario170979
Hello Jelte,
thanks at first. yes it work. but i found out that with our model we get the  wrong edges constraint. Is it possible to modificate it so that i can select on the first part the edge which should constraint?
In the picture:
Blue is the edge i need and and a other  is selected. Otherwise we had to modificate some hundred old models to fix this.
MR
