adding value to custom iproperties in parts from assembly document
sachin_kumar6CZM2
Message 1 of 8
sachin_kumar6CZM2
Hello Everyone,
I have to add certain custom iproperties to my part. All parts are sheet metals( comprises of 3mm and 4mm Aluminium sheets) and are assembled in an assembly. I don't want to open each part file and add the value /run the rule. I am looking for a i logic rule which can be run from the assembly file and will add the required custom i properties value to the appropriate parts. below is the code I created, but It is not working. Could anyone please help me to crack this.
Sub Main
'Gets the Active Document
oDoc = ThisDoc.Document
'Saves this document
oDoc.Save
'Checks if the active document is an assembly
If oDoc.DocumentType = kAssemblyDocumentObject
	'Gets the assembly occurrences
	Dim oOccs As ComponentOccurrences
	oOccs = oDoc.ComponentDefinition.Occurrences
	'Call the subprocedure to traverse the assembly
	Call TraverseAssembly(oOccs)
End Sub
Public Sub TraverseAssembly(oOccs As ComponentOccurrences)
  Dim oOcc As ComponentOccurrence
For Each oOcc In oOccs
  Select Case Thickness
  Case 3
	  If iProperties.Value("Project", "Description") = "3mm Aluminium Coping" Then
   iProperties.Value("Custom", "Finish Spec Code") = "F11A"
iProperties.Value("Custom", "Finish Specification") = "RAL 7022 Umbra Grey  - 30% Gloss YL280F"
iProperties.Value("Custom", "Material definition") = "MP101 - G0030"
iProperties.Value("Project", "Checked By") = "NAC"
iProperties.Value("Project", "Revision Number") = "00"
iProperties.Value("Project", "Project")="56U0XXXX-BA"
	Else
	iProperties.Value("Custom", "Finish Spec Code") = "F01Z"
iProperties.Value("Custom", "Finish Specification") = "MILL"
iProperties.Value("Project", "Checked By")= "NAC"
	Case 4
iProperties.Value("Custom", "Material definition") = "MP101 - G0040"
iProperties.Value("Project", "Project") = "56U0XXXX-BA"
iProperties.Value("Project", "Description")="4mm Aluminium Strap"
End Select
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject
			Call TraverseAssembly(oOcc.SubOccurrences)
Next
End Sub
Replies (7)
Message 2 of 8
clutsa
Are you getting an error or just not seeing the results you expect?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 8
sachin_kumar6CZM2
Hi@clutsa
I am not getting any error in Ilogic compiler. But not seeing any results. Its like the rule is doing nothing
Message 4 of 8
clutsa
Looks like you just need to add the sub component to the iProperties...
Sub Main
oDoc.Save
End Sub
	'Logger.Debug("Thickness = {0}", Parameter(oOcc.Name, "Thickness"))
  Select Case Parameter(oOcc.Name, "Thickness")
  Case 3
	  If iProperties.Value(oOcc.Name, "Project", "Description") = "3mm Aluminium Coping" Then
   iProperties.Value(oOcc.Name, "Custom", "Finish Spec Code") = "F11A"
iProperties.Value(oOcc.Name,"Custom", "Finish Specification") = "RAL 7022 Umbra Grey  - 30% Gloss YL280F"
iProperties.Value(oOcc.Name,"Custom", "Material definition") = "MP101 - G0030"
iProperties.Value(oOcc.Name,"Project", "Checked By") = "NAC"
iProperties.Value(oOcc.Name,"Project", "Revision Number") = "00"
iProperties.Value(oOcc.Name,"Project", "Project")="56U0XXXX-BA"
	Else
	iProperties.Value(oOcc.Name,"Custom", "Finish Spec Code") = "F01Z"
iProperties.Value(oOcc.Name,"Custom", "Finish Specification") = "MILL"
iProperties.Value(oOcc.Name,"Project", "Checked By")= "NAC"
	Case 4
iProperties.Value(oOcc.Name,"Custom", "Material definition") = "MP101 - G0040"
iProperties.Value(oOcc.Name,"Project", "Project") = "56U0XXXX-BA"
iProperties.Value(oOcc.Name,"Project", "Description")="4mm Aluminium Strap"
End Select
Next
End Sub
Edit I also changed what the select case was looking at to make sure you're looking at the sub component.
Have you ever used the logger.debug to return variables so you can interpret what the code is passing?
Message 5 of 8
sachin_kumar6CZM2
Thanku for your help.
but i am getting the following error
Where, "A1925B:1" is a subassembly which comprises of 3mm and 4mm Aluminium sheet part files .
Message 6 of 8
jnowel
mine maybe is a longer route, but i have added some checks if the component occurrence is a sheetmetal or not.
Also, it can add a custom iproperty if it is missing/not yet defined yet in the part
Sub Main
oDoc = ThisApplication.ActiveDocument
oDoc.Save
End Sub
		If oOcc.Suppressed Then Continue For 'skip suppressed componenet occurrences
		'This needs to be before the Select Case so you can skip the
		'rules for the parts
			Continue For
		Dim oOccDoc As Document
		oOccDoc = oOcc.Definition.Document
		If Not (oOccDoc.DocumentType = kPartDocumentObject And oOccDoc.IsModifiable) Then Continue For 'check if part and is modifiable
		If Not (oOccDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For 'check if sheetmetal part
		Dim oSheetMetalCompDef As SheetMetalComponentDefinition
		oSheetMetalCompDef = oOccDoc.ComponentDefinition
		Dim oThickness As DoubleForEquals
		oThickness = CDbl(oSheetMetalCompDef.Thickness.Value) * 10 'get value and convert from cm to mm
		Dim oDesProp As PropertySet
		oDesProp = oOccDoc.PropertySets.Item("Design Tracking Properties")
		Dim oInvSumProp As PropertySet
		oInvSumProp = oOccDoc.PropertySets.Item("Inventor Summary Information")
		Select Case oThickness
			Case 3 'mm
				If oDesProp.Item("Description").Value = "3mm Aluminium Coping" Then
					Call Set_CustomiProp(oOccDoc, "Finish Spec Code", "F11A")
					Call Set_CustomiProp(oOccDoc, "Finish Specification", "RAL 7022 Umbra Grey  - 30% Gloss YL280F")
					Call Set_CustomiProp(oOccDoc, "Material definition", "MP101 - G0030")
					oInvSumProp.Item("Revision Number").Value = "00"
					oDesProp.Item("Checked By").Value = "NAC"
					oDesProp.Item("Project").Value = "56U0XXXX-BA"
				Else
					Call Set_CustomiProp(oOccDoc, "Finish Spec Code", "F01Z")
					Call Set_CustomiProp(oOccDoc, "Finish Specification", "MILL")
			Case = 4 'mm
				Call Set_CustomiProp(oOccDoc, "Material definition", "MP101 - G0040")
				oDesProp.Item("Description").Value =   "4mm Aluminium Strap"
		End Select
	Next
End Sub
Sub Set_CustomiProp(oDoc As Document, iPropName As String, iPropVal As String)
	Try
		oDoc.PropertySets.Item("User Defined Properties").Item(iPropName).Value = iPropVal
	Catch
		 oDoc.PropertySets.Item("User Defined Properties").Add(iPropVal, iPropName)
	End Try
End Sub
Message 7 of 8
clutsa
Sorry I’m working off my cellphone right now because our network is down.
move your check for if it’s an assembly up before your select case and run the select case as an else .
Message 8 of 8
sachin_kumar6CZM2
@jnowel , Thanku very much.. it worked perfectly..
learned a lot from your code.
