Adding UserParameter out of Assembly
schuermann.fabianNKRGP
I want to add a user parameter with a multi value list to every part in an assembly. My code adds the parameter but doesn't add the list. I've tried some things but did not find a solution for this.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
Dim oTester As String
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
	For Each oRefDoc In oRefDocs
		oDocPathName = oRefDoc.FullDocumentName
			If oDocPathName.StartsWith("U:\Paletti Norm")
			Else
			oPartDoc = ThisApplication.Documents.Open(oDocPathName, True)
			oPartDoc.Activate
			oPartDoc = ThisApplication.ActiveDocument
			oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
			Try
				oTester = oMyParameter.Item("Bauteiltyp")
				oPartDoc.Close(True)
			Catch
			oParameter = oMyParameter.AddByValue("Bauteiltyp", "Standard", UnitsTypeEnum.kTextUnits)
			MultiValue.SetList("Bauteiltyp", "Standard", "ZUKAUF", "ROHSTOFF", "FORMKÖRPER D", "FORMKÖRPER F", "FORMKÖRPER P")
			Dim userParams As UserParameters
			Dim param As Parameter
			userParams = oPartDoc.ComponentDefinition.Parameters.UserParameters
			For Each oPara As Parameter In userParams
			Dim oName As String = oPara.Name
			If oName = "Bauteiltyp_1" Then
				oPara.Delete
			Next
			End Try
	Next
This is the code I am using so far.
Michael.Navara
You can try this simplified version
Sub Main()
    Dim asm As AssemblyDocument = ThisDoc.Document
    For Each refDoc As Document In asm.AllReferencedDocuments
        'Skip non-part documents
        If refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Continue For
        AddMultiValueParameterToPart(refDoc, "MultiValueParam", "one", "two", "three")
    Next
End Sub
Sub AddMultiValueParameterToPart(part As PartDocument, paramName As String, ParamArray exprList As String())
    Dim partDef As PartComponentDefinition = part.ComponentDefinition
    Dim textExpressionList = exprList.Select(Function(s) String.Format("""{0}""", s)).ToArray()
    'Ensure parameter by name
    Dim param As UserParameter
    Try
        param = partDef.Parameters.UserParameters(paramName)
    Catch ex As Exception
        param = partDef.Parameters.UserParameters.AddByValue(paramName, exprList(0), "TEXT")
    End Try
    'Set expression list
    param.ExpressionList.SetExpressionList(textExpressionList)
End Sub
