Adding Parameters to Assembly parts
NachoShaw
Advisor Advisor
NachoShaw
Hi
Is there a method available to loop through a top level assembly and add 3 parameters to each part? Ideally with 'export as parameter' checked. I can find anything and i havent done much on parameters through code.
Appreciate any help
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
hi I have this code I have quickly added 2 more parameter in.
SyntaxEditor Code Snippet
'Define the open document
Dim oDoc As Document
oDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
ModelName = IO.Path.GetFileName(ThisDoc.ModelDocument.FullFileName)
'MessageBox.Show(ModelName)
If Not ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
    Return
For Each docFile In oDoc.AllReferencedDocuments
    'open the indexed file
    'true opens the file normaly
    'false opens the file programatically without generating the graphics
    ThisApplication.Documents.Open(docFile.FullFileName, True)
    oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
'creates a new "Numeric" parameter
myNewparam1 = "Parameter_Name1" ' replace Parameter_Name with your new name
myNewparamValue1 = "111" 'replace Parameter_value with your new value'convert for parameter in centremeters
myNewparamValue2 = myNewparamValue1 / 10
oParameter = oMyParameter.AddByValue(myNewparam1, myNewparamValue2, UnitsTypeEnum. kDefaultDisplayLengthUnits)
myNewparam2 = "Parameter_Name2" ' replace Parameter_Name with your new name
myNewparamValue2 = "222" 'replace Parameter_value with your new value'convert for parameter in centremeters
myNewparamValue3 = myNewparamValue2 / 10
oParameter = oMyParameter.AddByValue(myNewparam2, myNewparamValue3, UnitsTypeEnum. kDefaultDisplayLengthUnits)
myNewparam3 = "Parameter_Name3" ' replace Parameter_Name with your new name
myNewparamValue3 = "333" 'replace Parameter_value with your new value'convert for parameter in centremeters
myNewparamValue4 = myNewparamValue3 / 10
oParameter = oMyParameter.AddByValue(myNewparam3, myNewparamValue4, UnitsTypeEnum. kDefaultDisplayLengthUnits)
    docFile.Save
    docFile.Close
Next
iLogicVb.UpdateWhenDone = True
I also have this code that should tick the export box.
Parameter.Param(docFName,"Parameter_Name1").ExposedAsProperty = True
