Adding iLogic Rule Using the API
MegaJerk
MegaJerk
I've caught glimpses of how to do this (For instance, this plugin (Inventor LinkParameters)  http://labs.autodesk.com/utilities/ADN_plugins/) , but honestly feel stumped when trying to actually find information on any documentation of how to get from point A to point B. I can't seem to find anything about ilogic automation / rule creation / ilogic in general, in the object browser at all.
I know code like this exists
Option Explicit
Sub RuniLogicRule()
Dim iLogicAuto As Object
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
Dim ruleName As String
ruleName = "Rule0"
Dim rule As Object
Set rule = iLogicAuto.GetRule(doc, "Rule0")
If (rule Is Nothing) Then
  Call MsgBox("No rule named " & ruleName & " was found in the document.")
  Exit Sub
Dim i As Integer
i = iLogicAuto.RunRuleDirect(rule)
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Dim addIns As ApplicationAddIns
Set addIns = oApplication.ApplicationAddIns
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
(and even fixed the error it gave me due to the original code leaving something out) , but have no idea where any info on the GetRule method is.
If anyone could help to point me in the correct direction for documentation or could provide an example even, I would be most grateful, as I certainly failing to see a major piece of the puzzle.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
MjDeck
There is some documentation available.  If you open the LinkParameters solution in Visual Studio, you can find it on the Object Browser under Autodesk.iLogic.Interfaces.  Look at the IiLogicAutomation interface.  This has an AddRule function.
 This documentation is found in an XML file: Autodesk.iLogic.Interfaces.xml.  On Inventor 2011, this file is found in
C:\Program Files\Autodesk\Inventor 2011\Bin\iLogicBin
On 2012, it is found in
C:\Program Files\Autodesk\Inventor 2012\Bin
 We should be able to add more documentation and produce a .chm file in a future version.
Mike Deck
Software Developer
Autodesk, Inc.
MegaJerk
Is there a way to add a reference to this file in the VBA editor (that comes with Inventor)? Any time that I try to add it in the object browser it gives me the error of : Can’t add a reference to the specified file.
I have Visual Studios at home, but not here at work, which is why I am curious about adding it to the VBA editor if possible.
Thank you!
GitHub
MjDeck
You can't add it in VBA because it only exposes .NET interfaces, and not COM.
You can download a free version of Visual Studio (Visual Basic Express) at
http://www.microsoft.com/visualstudio/en-us/products/2010-editions/visual-basic-express
Mike Deck
Software Developer
Autodesk, Inc.
Walliguy
@MjDeck thank you for this reference, it was really helpful!
MjDeck
Hi @Walliguy - do you mean Autodesk.iLogic.Interfaces.xml?
For recent releases of Inventor, all the information in there is now available online. Here's the 2024 version.
Mike Deck
Software Developer
Autodesk, Inc.
Walliguy
Hey @MjDeck,
Yes I was referring the XML file. Thanks for the link, I have always navigated my way into the help documentation through Inventor.
Thanks again,
