adding grounded to keyboard shortcut
I struggle to find grounded in tools->customize->keyboard->categories->unknown menu
If anyone knows of a trick or where to find it that would be of great help to my work tempo.
Accepted solutions (4)
WCrihfield
There isn't a predefined tool in the listing for that specific function.
You would have to either create a button that runs the VBA macro code, or perhaps modify the Properties of the existing built-in Button Definition to set up a shortcut through by code.
By default, it has no shortcut.
The command name for that ControlDefinition is "AssemblyGroundCtxCmd".
You can execute it with the following line of iLogic code:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyGroundCtxCmd").Execute
Wesley Crihfield
(Not an Autodesk Employee)
Well that is just terrible. all menus should have option to be hotkeyed. Inventor is better than Solidworks on this. But not by much. Thanks for the help. Perhaps i one day, can figure out how use that code++ to shape Inventor properly.
Edit: opsy.
WCrihfield
Yep.  Sometimes you can modify the 'DefaultShortcut' for a ControlDefinition through a fairly simple code, but not for ones that are 'Built-in", like this one is.
The code would look something like this:
Dim oCD As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyGroundCtxCmd")
oCD.DefaultShortcut = 'String type data here
Wesley Crihfield
rayessle
Not quite the same but if you right click on the part (either in the tree or on screen) then press the "g" key on your keyboard it will ground it, or un-ground it if already grounded. Same as "v" switches visibility. When you see the menu after you right click you will see letters that are underlined in the commands. These are the keys you can press as a shortcut instead of clicking. You would still have to click on the part before pressing a hotkey so the number of clicks is the same just a right click instead of a left click.
Regards
Ray
k14348
   Go to customize and add key for ground and root component. ss attached for ref.
-Karth
WCrihfield
That one is:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_GroundAndRootComponentCmd")
If you have the Assembly Bonus Tools installed, this command will Ground and constrain & align its origin to the origin of the assembly...not just ground it.
Wesley Crihfield
