adding custom made ribbon panel to a Ribbon tab that add by another addin
Mehmet_Fatih_Turker
Mehmet_Fatih_Turker
Hi all,
İt's sound weird but I need answer to that question, So, is it possible to add a ribbon panel that is made by addin to a ribbon tab that is added by another addin ? I have Ribbon tabs ID name.
BM_Ashraf
Hi @Mehmet_Fatih_Turker
I think that's possible. I'm currently testing something similar. but still not finished yet.
But what i can gurantiee that you can get the Command control and Button definitions and add them to any Ribbon Tab you wish and it will do the same job.
Here is an example of how to get any button definition
Dim oDef As ButtonDefinition
Set oDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd") ' Change the '"AppLocalUpdateCmd" with the button you wish
Then Add it to any Ribbon or Ribbon Tabs you wish
Dim oRibbons As Ribbons
Set oRibbons = ThisApplication.UserInterfaceManager.Ribbons
Dim oRibbon As Ribbon
Set oRibbon = oRibbons("Assembly")
Dim oRibbonTab As RibbonTab
Set oRibbonTab = oRibbon.RibbonTabs("Please insert the Tab Internal Name")
Dim oAssRibbonPanel As RibbonPanel
Set oAssRibbonPanel = oRibbonTab.RibbonPanels.Item("Please insert the Tab Internal Name")
Dim oCMDControl As CommandControl
set oCMDControl = oRibbonTab.CommandControls.AddButton(oDef)
Hope this helps you to move forward!
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
