Adding custom iproperty to selected parts in an assembly
m.rymut
m.rymut
i have a rule that lets me add 5 custom properties to a part.
I wanted to modify the rule so that i can run it in an assembly and add those 5 iproperties to all selected parts.
The rule i use ( it is a rule i found on this Forum and modyfied it):
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim iprop(5) As String
iprop(1) = "Materiał"
iprop(2) = "Wykończenie"
iprop(3) = "Kolor"
iprop(4) = "Opis"
iprop(5) = "Informacje dodatkowe"
For k = 1 To 5
Dim prop(k) As String
    Try
        prop(k) = iProperties.Value("Custom", iprop(k))
    Catch
        'Assume error means not found
        customPropertySet.Add("", iprop(k))
        iProperties.Value("Custom", iprop(k)) = "null"
    End Try
Next
For j = 1 To 5
    Dim var(j) As String
    If iProperties.Value("Custom", iprop(j)) = "null" Or iProperties.Value("Custom", iprop(j)) = "" Then
        var(j) = InputBox("Proszę wpisać wartość dla: " & iprop(j), "Warning", "")
        iProperties.Value("Custom", iprop(j)) = var(j)
		Else
			If j = 1 Or j= 3 Or j= 4 Then
			question = MessageBox.Show(iprop(j) & " jest już określony: " & vbLf & iProperties.Value("Custom", iprop(j)) & vbLf & "Czy chcesz zmienić " & iprop(j) & "?", "IProperty już określone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
				If question = vbYes Then
				var(j) = InputBox("Proszę wpisać nową wartość dla: " & iprop(j), "Warning", "")
			Else
				If j = 2 Then
				question = MessageBox.Show(iprop(j) & " jest już określone: " & vbLf & iProperties.Value("Custom", iprop(j)) & vbLf & "Czy chcesz zmienić " & iprop(j) & "?", "IProperty już określone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
				Else
					If j = 5 Then
					question = MessageBox.Show(iprop(j) & " są już określone: " & vbLf & iProperties.Value("Custom", iprop(j)) & vbLf & "Czy chcesz zmienić " & iprop(j) & "?", "IProperty już określone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
Next
I tried modifying it by adding oSelect but i couldnt get it to work
A.Acheson
Here is your rule integrated into a pick assembly occurrence rule. At the moment when all occurrence have been picked each file is processed separately. If you want to process them all with the same iProperties and values  the rule will need to be changed to suit.
'Description of the Rule and if you want to continue
 Result = MessageBox.Show("Do you want to continue?" _
& vbNewLine &"" _
& vbNewLine & "This rule allows you to browse the tree and select multiple items,then press the Esc Key and have an action carried out" _
& vbNewLine & "", "Browse And Select" _
, MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button2)
If Result = vbNo Then
	MessageBox.Show ("Rule Canceled Exiting", "Title")
ElseIf Result = vbYes Then
	Dim oDoc As AssemblyDocument
	oDoc = ThisDoc.Document
	oCompDef = oDoc.ComponentDefinition
	Dim oSet As HighlightSet
	oSet = oDoc.CreateHighlightSet
	'MessageBox.Show ("Rule will Run", "Title")
	'[Pick Assembly Occurrences
	Dim comps As ObjectCollection
	Dim comp As Object
	comps = ThisApplication.TransientObjects.CreateObjectCollection
	While True
		comp = ThisApplication.CommandManager.Pick(
			SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,
			"Select a component")
		' If nothing gets selected then we're done
		If IsNothing(comp) Then Exit While
			comps.Add(comp)
			oSet.AddItem(comp)
	End While
	Result = MessageBox.Show("Do you want to process all Selected?", "Process selected files", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button2)
	MessageBox.Show ("Rule Cancelled", "iLogic")
	 'If there are selected Components we can Do something
		For Each comp In comps
			'Pick only parts
			If comp.DefinitionDocumentType = kPartDocumentObject Then
				'Get document of each occurrence
				Dim oOccDoc As Document
				oOccDoc = comp.Definition.Document
				'[Add custom iProp
				customPropertySet = oOccDoc.PropertySets.Item("Inventor User Defined Properties")
				iprop(1) = "Material"
				iprop(2) = "Wykonczenie"
				iprop(3) = "Kolor"
				iprop(4) = "Opis"
				For k = 1 To 5
				    Try
				        prop(k) = iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(k))
				    Catch
				        iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(k)) = "null"
				    End Try
				Next
				For j = 1 To 5
				    If iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(j)) = "null" Or iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(j)) = "" Then
				        var(j) = InputBox("Prosze wpisac wartosc dla: " & iprop(j), "Warning", "")
				        iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(j)) = var(j)
						Else
							question = MessageBox.Show(iprop(j) & " jest juz okreslony: " & vbLf & iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(j)) & vbLf & "Czy chcesz zmienic " & iprop(j) & "?", "IProperty juz okreslone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
								var(j) = InputBox("Prosze wpisac nowa wartosc dla: " & iprop(j), "Warning", "")
							Else
								If j = 2 Then
								question = MessageBox.Show(iprop(j) & " jest juz okreslone: " & vbLf & iProperties.Value("Custom", iprop(j)) & vbLf & "Czy chcesz zmienic " & iprop(j) & "?", "IProperty juz okreslone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
								Else
									If j = 5 Then
									question = MessageBox.Show(iprop(j) & " sa juz okreslone: " & vbLf & iProperties.Value(oOccDoc.DisplayName,"Custom", iprop(j)) & vbLf & "Czy chcesz zmienic " & iprop(j) & "?", "IProperty juz okreslone", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
				Next
				MessageBox.Show (comp.Name, "iLogic")
			Else
				MessageBox.Show ("An Assembly file:-" & comp.Name & " was selected so skipping", "iLogic")
		Next
	MessageBox.Show("Files Processed", "iLogic")
	'Clear Highlighting
	oSet.Clear()
Regards
Alan
m.rymut
Works great, thank you very much.
