Adding BendNote (DrawingCurve) works in VBA but not VB?
mthomas
mthomas
If I iterate through the DrawingCurves in a drawing view in VBA looking for kBendDownEdge or kBendUpEdge I am able to add BendNotes to the found curves.
This same logic does not work in VB.net. It errors "Exception User-Unhandled" System.Runtime.InteropServices.COMException: 'Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))'
I'm not sure why and don't know how to proceed to make it work.
Public Sub VBA_BENDNOTE()
        Dim oDoc As DrawingDocument
        Set oDoc = ThisApplication.ActiveDocument
        Dim oSheet As Sheet
        Set oSheet = oDoc.ActiveSheet
        Dim oCurve As DrawingCurve
        Dim myView As DrawingView
        Set myView = oSheet.DrawingViews.Item(1)
        Dim myBendNote As BendNote
        For Each oCurve In myView.DrawingCurves
            If oCurve.EdgeType = kBendDownEdge Or oCurve.EdgeType = kBendUpEdge Then
                Set myBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
        Next
End Sub
Private Sub AddBendNotes(oSheet As Sheet)
        Dim oBendNote As BendNote
        Dim myView As DrawingView = oSheet.DrawingViews.Item(1)
            If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge Or Inventor.DrawingEdgeTypeEnum.kBendUpEdge Then
                oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
        Next
    End Sub
Mike Thomas
Cadkunde.nl
Helped someone with bend notes on drawingcurve a while ago,
He had a working ilogic script that adds bend notes:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/remove-bend-note-for-high-bend-radiu...
mthomas
That works in VBA and in iLogic but is failing for me in VB.Net, so strange. I'm at a loss on what to do.
Mike Thomas
WCrihfield
The one tip I might add here is that, even though DrawingCurves is 'Property' of the DrawingView object, it acts like a Method (a Function), and returns a collection type result every time it is used.  So it is best to use it once to set the value of a variable before that start of the loop.  Then use that variable as the collection you are looping through, instead of using that Property directly as the collection to loop through, so it is not re-running that function every time, essentially re-setting the collection each time.  It might work in some situations that way, but it is best to do it the way I suggested above.
So, change this:
to:
Dim oCurves As DrawingCurvesEnumerator = myView.DrawingCurves
For Each oCurve In oCurves
You might also want to wrap your line that creates the bend note inside of a Try...Catch block, for good measure, and maybe add a Logger.Error() or MsgBox() in the Catch side, as feedback.  There may just be some odd status/property about some curves that it doesn't like.  Just some thoughts.
Wesley Crihfield
(Not an Autodesk Employee)
mthomas
Thanks for the suggestions. Adding the Try...Catch let me figure out that the EdgeType check needs to be Inventor.DrawingEdgeTypeEnum.kBendExtentEdge in VB.net
However, it's still failing on adding the BendNote, even adding the oCurves.
As its VB not iLogic I can't add an Logger.Error(), but will go the debug.print route and see if I can narrow down the differences.
Any other suggestions?
If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendExtentEdge Then
Mike Thomas
JelteDeJong
Just as a side note. I have 2 blog posts that might interest you. The first explains why I think you should stop using VBA: "Is VBA in Inventor obsolete?" But maybe you find the post: "Automatically generate bend notes" more interesting. There you will find this iLogic rule which creates bendnotes using iLogic.
Dim view As DrawingView = ThisApplication.CommandManager.Pick(
	           SelectionFilterEnum.kDrawingViewFilter,
	           "Select a drawing view")
If (view Is Nothing) Then Return
Dim bendCurves = view.DrawingCurves.Cast(Of DrawingCurve).
    Where(Function(curve) curve.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge Or
                          curve.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge).ToList()
Dim bendNotes = view.Parent.DrawingNotes.BendNotes
For Each curve As DrawingCurve In bendCurves
    bendNotes.Add(curve)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
mthomas
Thanks, I will take a look.
I was only using VBA in hopes to find out why it was failing in VB.NET. I don't use VBA normally.
Mike Thomas
