Message 1 of 13
Adding balloons automatically API
06:55 AM
Hello all,
I am trying to add balloons in an assembly with a code sample I got from an inventor atomation demo by Thomas Fitzgerald: https://www.autodesk.com/autodesk-university/class/Taking-It-Next-Level-Drawing-Automation-Inventor-...
Sub Create_Balloon
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oActiveSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawingView As DrawingView = oActiveSheet.DrawingViews.oFrontview
Dim oAssemblyDoc As AssemblyDocument = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
oDrawingView.ViewStyle = 32257
'*** Iterate through Assembly to find Parts
Dim oOccs As ComponentOccurrences = oAssemblyDoc.ComponentDefinition.Occurrences
For Each oOcc As ComponentOccurrence In oOccs
If oOcc.DefinitionDocumentType = 12291 Then
Call TraverseSubAssy(oActiveSheet, oDrawingView, oTG,
oOcc.SubOccurrences)
Else
Call CreateBalloon(oActiveSheet, oDrawingView, oTG,
oOcc)
Next
oDrawingView.ViewStyle = 32258
End Sub
Private Sub TraverseSubAssy(oActiveSheet As Sheet, oDrawingView As DrawingView, oTG As TransientGeometry, oOccs As ComponentOccurrences)
Else
oOcc)
Next
End Sub
Public Function CreateBalloon(oActiveSheet As Sheet, oDrawingView As DrawingView, oTG As TransientGeometry, oOcc As ComponentOccurrence)
Dim oModelDoc As Inventor.PartDocument
oModelDoc = oOcc.Definition.Document
'*** Find the tagged Faces
Dim oObjs As ObjectCollection = oModelDoc.AttributeManager.FindObjects("*", "*", "Balloon")
If oObjs.Count = 0 Then Exit Function
Dim oFace As Inventor.Face
oFace = oObjs.Item(1)
Dim oFaceProxy As Inventor.FaceProxy
Call oOcc.CreateGeometryProxy(oFace, oFaceProxy)
Dim oDrawCurves As Inventor.DrawingCurvesEnumerator
oDrawCurves = oDrawingView.DrawingCurves(oFaceProxy)
Dim oDrawingCurve As Inventor.DrawingCurve
oDrawingCurve = oDrawCurves.Item(1)
Dim midPoint As Point2d = Nothing
midPoint = oDrawingCurve.MidPoint
Dim oLeaderPoints As ObjectCollection =
ThisApplication.TransientObjects.CreateObjectCollection
'*** Locate where the Balloon will be placed
If midPoint.X > oDrawingView.Position.X Then
oLeaderPoints.Add(oTG.CreatePoint2d(midPoint.X + 2, midPoint.Y- 1))
Else
oLeaderPoints.Add(oTG.CreatePoint2d(midPoint.X - 2, midPoint.Y- 1))
'*** Must be the LAST point added to the array. This is the Balloon Leader attachment Point.
Dim geoIntent As Inventor.GeometryIntent =
oActiveSheet.CreateGeometryIntent(oDrawingCurve, .5)
oLeaderPoints.Add(geoIntent)
'*** Create the balloon
Dim oBalloon As Inventor.Balloon
oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints)
End Function
The problem is that the code seems to do nothing. No errors an no balloons show up either.
I named the surfaces by right clicking them and using the assign name option.
Is this the wrong method or is there an error in the code?
thank you for your help in advance.
With kind regards,
Lennart
