Hello Eveyone,
I've been pulling my hair out for the afternoon trying to find any method what-so-ever to add our drawing approval stamp automatically when a user runs a macro. It doesn't matter how or what, i just need our stamp to appear and the date in the textbox to update to now(). Currently I have:
Public Sub StampDWG()
Dim oDWG As DrawingDocument
Dim dateBox As TextBox
If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
MsgBox "This program must be run on an AutoBin generated drawing."
Exit Sub
Set oDWG = ThisApplication.ActiveDocument
DD = Day(Now())
MM = Month(Now())
yy = Year(Now())
dateStr = "("
If DD < 10 Then
dateStr = dateStr & "0" & DD & "/"
GoTo addMonth
dateStr = dateStr & DD & "/"
addMonth:
If MM < 10 Then
dateStr = dateStr & "0" & MM & "/"
GoTo addYear
dateStr = dateStr & MM & "/"
addYear:
dateStr = dateStr & yy & ")" 'dateStr basically becomes example (05/31/2011)
Call oDWG.Sheets(1).SketchedSymbols.Add("MMG_APPROVAL_STAMP", ThisApplication.TransientGeometry.CreatePoint2d(6 * 2.54, 3.4 * 2.54), 0, 0.8)
Dim oSymbol As SketchedSymbol
For Each oSymbol In oDWG.ActiveSheet.SketchedSymbols
Debug.Print oSymbol.Name
If oSymbol.Definition.Name = "MMG_APPROVAL_STAMP" Then
oSymbol.Definition.Sketch.TextBoxes(4).FormattedText = dateStr
On the last line I get an error
Run-time error '-2147467259 (80004005)':
Method 'FormattedText' of object 'TextBox' failed
Same error when using .text method
I added this and get an error on the .edit line
oSymbol.Definition.Sketch.Edit
oSymbol.Definition.Sketch.ExitEdit
i get the same error number saying the method failed.
