Addind Coments Through iLogic
Hello All,
I am wondering if there is a way to have to add iProperty Comments through iLogic? I am wanting to break down the assembly down to sub assemblies to parts.
Such as Main assembly is 001, sub assemblies start at 002 and then parts start whenever the sub assemblies end. So essentially the code would count through the files and count accordingly.
This is very possible, so just to be clear you want to add an iProperty to each assembly or part, with its value being the BOM level of that file?
Yes, basically the main assembly will be 001 and then have it go through the structure BOM and then the PArts only BOM
Hope this iLogic rule does what you need.
It will look for a custom parameter named "Level" in each assembly/part, add it if it doesn't exist and set its value to the BOM level of that item.
Let me know if you want this behaviour altered, you may not want the iProperty to be added to every item in your BOM, in which case can be easily fixed.
Sub Main TraverseAssembly()
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim Level As Integer = 1
Dim myStr = Level.ToString("D3")
Try
    'try to set iProperty value
    oAsmDoc.PropertySets.Item("Inventor User Defined Properties").Item("Level").Value = myStr
Catch
    'catch error when iProperty doesn't exist and create it
    oAsmDoc.PropertySets.Item("Inventor User Defined Properties").Add("","Level")
    'set iProperty value
End Try
' Call the function that does the recursion.
Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, Level + 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        'define custom property collection
        oCustomPropertySet = oOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties")
        Try
            oCustomPropertySet.Item("Level").Value = myStr
        Catch
            oCustomPropertySet.Add("","Level")
        End Try
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
    Next
End Sub
