Addin/Form question.
I'm trying to create small addin application using VB6.
I have problems when I tries to "access" the Custom Properties from a added
Form in my application.
I got all kind or errors but mostly "Object variable or With block variable
not set" (Error code 91.)
I think I'm doing something wrong when I declare the objects.
I have used: "Private oApp As Inventor.Application"
Someone that has an idea or have a piece of code from a "Form" within a
addin. (ActivX dll)
Lars Andersson
Hi Lars
That message shows up when I forget to use the SET statement
i.e.
oApp = AddInSiteObject.Application
vs
Set oApp = AddInSiteObject.Application
Have you looked at the Sample Addin in the SDK folder and compared with what
you have?
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Lars Andersson" wrote in message
news:840EA3B33A74E4F24DEBB008445FD679@in.WebX.maYIadrTaRb...
> Hi,
added
variable
ars Andersson
Thanks Kent, that did it.
Lars
"Kent Keller" skrev i meddelandet
news:61C3B9A5838379256DEFDB33BC24198B@in.WebX.maYIadrTaRb...
> Hi Lars
> i.e.
> vs
what
> you have?
> Kent Keller
> Assistant Moderator
> > Hi,
> added
> variable
> ars Andersson
