I've search for references to AddDiameter and there is very little. Tells me no one uses it or it should be pretty easy.
I've got he following:
Public Sub BP() ' Create a new part document, using the default part template. Dim oPartDoc As PartDocument Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _ ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)) ' Set a reference to the component definition. Dim oCompDef As PartComponentDefinition Set oCompDef = oPartDoc.ComponentDefinition ' Create a new sketch on the X-Z work plane. Since it's being created on Dim oSketch As PlanarSketch Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(2)) ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry Set oTransGeom = ThisApplication.TransientGeometry ' Draw a 4cm x 3cm rectangle with the corner at (0,0) Dim oc As SketchCircle Set oc = oSketch.SketchCircles.AddByCenterRadius(oTransGeom.CreatePoint2d(0, 0), 24 * 2.54) Dim DimC As DimensionConstraint DimC = oSketch.DimensionConstraints.AddDiameter(oc, oTransGeom.CreatePoint2d(3, 3), False) end sub
Basically, it just creates a circle and then tries to dimension it.
The code actually places a diameter dimension on the sketch, but it errors every time saying Run time error '91' - object variable or With block variable not set.
I'm not seeing anything that tells me what the problem is, other than debug points to the DimC - osketch............ line where the constraint is created/placed.
If it can place the constraint, why is it creating an error presumably after the fact?
