Add reuse component from main assembly to new
1830108CDDDF
1830108CDDDF
Hello everyone, reading some threads I found this one: Using iLogic to Save As Components in an assembly
And the code in the thread It's what I need, but there's a little problem, I need to "save as" some specific components with a column named "EXPORTAR" (Export) and the cell value is a Yes or No.
Private Function oAsmSaveAs(oDoc As AssemblyDocument,oPath As String)
Dim oFileName As String = oGetFileName(oDoc,oPath)
Dim oNewAsmDoc As AssemblyDocument
If Not System.IO.File.Exists(oFileName) Then
	oNewAsmDoc=ThisApplication.Documents.Add(Inventor.DocumentTypeEnum.kAssemblyDocumentObject,,True)
	oNewAsmDoc.SaveAs(oFileName, False)
Else
	Exit Function
Dim oNewdef As AssemblyComponentDefinition
oNewdef = oNewAsmDoc.ComponentDefinition
Dim oNewCC As ComponentOccurrence
Dim odef As AssemblyComponentDefinition
odef=oDoc.ComponentDefinition
Dim oCC As ComponentOccurrence
Dim oNewPartName As String
For Each oCC In odef.Occurrences
	If oCC.Suppressed Then
	Else
		If oCC.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
			Dim oPrt As PartDocument
			oPrt = oCC.Definition.Document
			Dim oProp As String
			oProp = oPrt.PropertySets.Item(4).Item("EXPORTAR").Value
'		MessageBox.Show(oProp,"Title")
			If oProp = True Then
				oNewPartName=oGetFileName(oPrt,oPath)
				Call oDocSaveAs(oPrt,oNewPartName)
				oNewCC = oNewdef.Occurrences.Add(oNewPartName, oCC.Transformation)
				oNewCC.Grounded=True
			Else
				Dim oRComponent As ComponentOccurrence = odef.Occurrences.Add(odef, oCC.Transformation)
		ElseIf oCC.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oSubAsm As AssemblyDocument
			oSubAsm = oCC.Definition.Document
			Call oAsmSaveAs(oSubAsm, oPath)
			oNewPartName=oGetFileName(oSubAsm,oPath)
			oNewCC = oNewdef.Occurrences.Add(oCC, oCC.Transformation)
Next
oNewAsmDoc.Close
End Function
In the function above through an If is chosen the component wether or not the component is saved
When executing the rule, exports correctly the components with the "EXPORTAR" cell marked as Yes, but the components with the "No" value aren't wich is I expected. What I'd like to do is to reuse the source component in the new assembly, I try with de Add method
But it gives me an error, in my understanding I need to add the oCC but is not working.
Wich would be the correct method to achieve this?
Thanks in advance, regards.
A.Acheson
Hi @1830108CDDDF
In the adding occurrences I see two mistakes, one is trying to add a componentdefinition with the wrong add method and the other uses the occurrence only. You should either use ".add" for fullfilename or ".AddByComponentDefinition" for componentdefinition
Error lines
I would suggest to change around those lines and report back what further issues your facing.
Regards
Alan
