Add properties for Revit file through Ilogic
Kassenbouw
Kassenbouw
I'm using an external rule to create a rfa file. I would like to add some properties to this file.
Manually I can create / fill in these properties in the BIM envirement at Author Building Components. Is there a way to do this through ilogic?
JelteDeJong
Did you see the post: "Edit a BIM Connector via iLogic". In that post i added Bim information to a part.
Jelte de Jong
Blog: hjalte.nl - github.com
Kassenbouw
Hoi Jelte,
I'm getting a error when I run your code:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Assets.get_Item(Object Index)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
I'm running the code in an part.
